C5 brake swap started
Goto page Previous  1, 2, 3
PostPosted: Wed Sep 10, 2008 11:52 am    Post subject: Reply with quote
http://cascadecrew.org/phpBB2/viewtopic.php?t=4666&postdays=0&postorder=asc&start=0
http://www.thirdgen.org/techboard/faq-board/183169-98-camaro-ls1-brakes-5.html
You can by a kit from Ed Miller on TGO. Its pretty straightforward. Parts are cheapish if you cut down your existing hub/rotor and reuse your spindles. New rotors are $50/ea, I got my calipers and brackets for $150. Follow the links.
PostPosted: Wed Sep 10, 2008 11:54 am    Post subject: Reply with quote
cool thanks
PostPosted: Wed Sep 10, 2008 6:00 pm    Post subject: Reply with quote
blue89 wrote:
Al, did you have any troubles with the spindle-bracket bolts hitting the caliper? My caliper won't go all the way on cause its hitting the bolt heads Confused I have my hubs cut and one rotor for fitment. I'm thinking about clearancing the caliper bracket so it fits.
I have no clearance issues with mine. From the pictures you posted of yours, they appear to be clocked a little lower than mine, I don't have any clearance issues with the steering stop on the spindles either.
Check this out (a TGO link so you may have to sign on)
I think Tony had a similar issue with his in this post.
http://www.thirdgen.org/techboard/posts/faq-board/183169-98-camaro-ls1-brakes/3370293-post702.html
From this thread http://www.thirdgen.org/techboard/faq-board/183169-98-camaro-ls1-brakes.html
Looks like I referenced one of the same threads you did Laughing
Greg, I bought most of my stuff used, but I still have alot of money into these. Junkyard spindles with rotors were $35 apiece, machine work to turn the rotors down into hubs was 2 hrs shop time ($160). Caliper brackets were $100. C5 calipers with pads and rotors from Ian was $300. On top of that was the other little things like wheel bearings, brake fluid (lots), misc tools I didn't have. Not real cheap, but I learned alot doing it myself over a few weekends.
PostPosted: Wed Sep 10, 2008 6:29 pm    Post subject: Reply with quote
GREG DAVIDSON wrote:
i wanna do this to my car how laber intensive is it and whats the price on parts run normaly ? i kinda run on a budget could someone give me some links to check out ??
PostPosted: Wed Sep 10, 2008 6:34 pm    Post subject: Reply with quote
i thought about going that rout but the junk yards around here have nothing but well junk Laughing mostly forien junk go fig but i am still in the planning fase of my car
Page 3 of 3
