Posted: Wed Jun 04, 2008 5:26 pm Post subject: Deja Vu |
Almost a little worse then the last one...
This time instead of going past the school bus.. I was driving past the school. It did make it to work though, and only took a 1/2 hour and a few bucks to fix. |
Posted: Wed Jun 04, 2008 5:31 pm Post subject: |
| That's with the full rollers? Or this on the other rig?! |
Posted: Wed Jun 04, 2008 5:52 pm Post subject: |
| Interesting. Was this the truck? ?? Coil bind or retainers making contact or something ? |
Posted: Wed Jun 04, 2008 6:21 pm Post subject: |
| This is the truck. Which has been running with these parts since last summer. Except i've swapped 1.6 roller tips for 1.6 full rollers.And had the same problem occur. |
cameron7710 Member
Posted: Wed Jun 04, 2008 7:41 pm Post subject: |
dam dude ur truck dosent like school _________________
BigDaddyVu 12sec Club
Posted: Wed Jun 04, 2008 8:24 pm Post subject: |
i had too buy different length for roller rockers on mine. there shorter than stock depending if your using aluminum rocker or stamp roller rockers.
Are you using guide plates or girdles? rollers float. _________________
Posted: Fri Jun 06, 2008 11:15 am Post subject: |
I had a push rod in my '85 Z28 305 TPI actually break in half. This was on a bone-stock engine. The valve covers had probably never been off. No one seemed to know what caused it.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Jun 06, 2008 11:54 am Post subject: |
I had a similar thing happen with my LG4 that was in my old 85 Z/28.
previous owner put the wrong kind of nut on #7's intake stud, and just torqued the bejeezus out of it. Ended up almost pulling the stud out, cracking it at the base, bending the pushrod.
ended up having to replace the whole head. _________________
Posted: Fri Jun 06, 2008 4:40 pm Post subject: |
| What the hell you got going on there B? |
Kage87Z Member
1969 Chevrolet Camaro
Posted: Fri Jun 06, 2008 6:21 pm Post subject: |
| Nothing to get bent out of shape over. |
Posted: Sat Jun 07, 2008 8:43 am Post subject: |
The bent pushrod is just a symptom. When the rocker stud breaks first, causing a hellacious backfire out the intake since its an exhaust valve. Then when I shut the truck off that rocker falls down and gets in the way of the neighboring intake rocker. Next time I crank the engine over, it bends the pushrod.. no more popping out the intake.
These studs are just not long or strong enough. The one's i'm replacing them with are old pioneer units, which are a hair longer and arent the black chromium looking material. The ones that are breaking are mr gasket chinese crap. Not having much luck finding anything else in a replacement type screw in stud either. May have to call summit or arp themselves and see if they offer anything at all. I'm also going to have a closer look at the valvetrain geometry. This motors far too noisey. |
Posted: Mon Jun 09, 2008 5:04 pm Post subject: |
| Well I borrowed Paul's adjustable checking pushrod this weekend. Ran it yesterday to check geometry. And I'm nearly perfect as is. If anything, the stock pushrods may be just a hair long. The roller line is just to the outside of center.. barely. Longer pushrod just moves things further from there. Looks like I've just got crappy rocker studs. |
