charcoal evaporation canister....thing
jakemk8706
PostPosted: Wed May 28, 2008 7:37 pm    Post subject: charcoal evaporation canister....thing Reply with quote
how necessary is this?
from what i understand the tank needs this to vent the vapors, so if i take out the canister and route that hose coming from the tank outside the car and plug the vacuum line going to the throttle body, it wont hurt anything right?
or will my car run like crap?
(im registered in molalla so i don't emissions)
gas brake dip dip
PostPosted: Wed May 28, 2008 7:41 pm    Post subject: Reply with quote
it will not affect how the car runs at all. the only thing is that now you will have an open vent under your hood. i put a little air filter on it. Rolling Eyes another option is to seal it, but then your tank can become pressurized. you can also get a vented gas cap. i have found theat a vented cap allows gas to vent out too, so i think i'll be sealing mine up.
if your charcoal canister actually works you might as well leave it. otherwize ditch it's dead weight.
PostPosted: Wed May 28, 2008 7:43 pm    Post subject: Reply with quote
The tank still needs to be vented, otherwise it will suck air every time you take the cap off. My vent line has a cheapo carb fuel filter clamped inline, with a section of fuel line routed down behind the front bumper.
*Edit: Ninja'd by Tony. Sad
PostPosted: Wed May 28, 2008 7:45 pm    Post subject: Reply with quote
jakemk8706
PostPosted: Wed May 28, 2008 8:15 pm    Post subject: Reply with quote
ninja please!
well it works fine but its in my way, so i guess ill see what happens when i take it out.
gas brake dip dip
PostPosted: Wed May 28, 2008 9:17 pm    Post subject: Reply with quote
I ditched mine and run a carb fuel filter in the vent line.
PostPosted: Wed May 28, 2008 10:01 pm    Post subject: Reply with quote
Hook the line up directly to the intake ducting. No smelly gas. No Canister.
PostPosted: Thu May 29, 2008 12:26 am    Post subject: Reply with quote
hmm... neat.
jakemk8706
PostPosted: Thu May 29, 2008 9:28 am    Post subject: Reply with quote
where abouts on the intake ducting?
gas brake dip dip
PostPosted: Thu May 29, 2008 9:30 am    Post subject: Reply with quote
Paul, is there some kind of check valve in the vent line? Somehow running a line from a sealed fuel tank to a potential vacuum seems like a slightly explosive idea. Confused
jakemk8706
PostPosted: Thu May 29, 2008 10:47 am    Post subject: Reply with quote
hmmm...explosions are pretty cool.
but i think i may want to avoid one when im in the middle of it, so im gonna try just venting it outside the car or something.
gas brake dip dip
