'92 camaro boss Member
Posted: Fri May 09, 2008 9:22 am Post subject: Buzzer |
| Ok, i'm one of those people that have a nasty habbit of leaving the lights on when i get outta my car at dusk.. all the other car's i've drivin (including my '86 sc) have had a buzzer when you open the door and for the lights.. but my 92 does not have it.. i was woundering if all camaro came equiped with it, and if so, what should i look for to replace? |
Posted: Fri May 09, 2008 9:31 am Post subject: |
| Do you have the buzzer for anything else (i.e. seatbelts, ignition key, ect.)? When my headlight switch was going out it wouldn't buzz for lights, but it would for everything else. |
Posted: Fri May 09, 2008 9:33 am Post subject: |
| no noises what-so-ever i've checked fuses and their all good |
Posted: Fri May 09, 2008 10:01 am Post subject: |
Mine is out right now and sitting in the console. I'll try to remember to get a shot of it after I get home. Can't get a shot of where it goes, too many wires for other gadgets in the way. _________________ 92 Camaro
Posted: Fri May 09, 2008 10:08 am Post subject: |
| So it's going to be a mess to get to?.. i still havn't changed my dimmer switch because it's too much of a pain to reach |
Posted: Fri May 09, 2008 10:28 am Post subject: |
No, mine's a mess to get to. At least the one in the 92 is due to alarm wiring, digital dash wires, alarm window module, etc  |
Posted: Fri May 09, 2008 10:31 am Post subject: |
Woooow my car's basic compared to yours..
Hey speaking of your digital dash, would it still work if you were to swap an LS1 or an LT1?
and back to subject minus all that am i able to get to it relitively easy? |
Posted: Fri May 09, 2008 10:57 am Post subject: |
| It should without any problems, just find the right wires to tap/splice into. You probably don't want to spend the $1050 that Dakota Digital wants to built that dash now, since I've had mine for 4+ years, it was considerably less. Nordskog makes one also that looks nice, but you have to assemble it, hookup is basically the same though. |
Posted: Fri May 09, 2008 11:07 am Post subject: |
| yea i read what you posted on TGO and i'd be going with the Nordskog idk, that's a conversion that would happen way down the road.. |
Posted: Fri May 09, 2008 5:46 pm Post subject: |
Your buzzer module should look like this. I still need to get under the dash and plug mine in. It is for all the reminders, lights, keys, seat belt, etc. It hooks up in the convenience center where the horn relay and hazard flasher module are. Mine is between the steering column and the radio console (almost on the attached to the console).
