STEEL Member
Posted: Tue Apr 29, 2008 1:24 am Post subject: Well, I think I may have severely screwed myself. |
Due to rising gas prices I parked my half finished camaro outside and let it sit for a month. It was running when I parked it, but a month later it wouldn’t start. I now think I know why.
When I parked it, I had the flaps removed from my hood, and I had noticed water was gathering on the top of my air cleaner. Because my hood clearance sucked, and I couldn’t afford to replace my cleaner with a shorter on, I flipped the lid over, creating a bowl.
I now believe the water traveled down the air cleaner post into the carb, then through the intake manifold, in the open valves, and into the cylinders. When I wanted to drive the car again, the engine was low on oil, so I added a few quarts, and went to start it up. Wouldn’t turn over. (Dead battery and rusted cylinder walls). Three of my friends start pushing, and I tried to bump start it. The engine wouldn’t turn over, and I left large skid marks. Tried this three times before the engine finally broke loose. Got the car to start, but it was having a lack of power.
Drove it for about 50 miles, gassed up and added some HEAT. Parked it and then a week later I found froth in the oil. My question for ya’ll is what can I do to repair the damage? I assume that my entire engine has rust inside, and I want to know if I can repair the damage without pulling it all apart. Is this something that can be “Blown out the exhaust” in a manner of speaking? |
Posted: Tue Apr 29, 2008 2:05 am Post subject: |
the froth is water that leaked past your rings (hopefully). change your oil and filter, run the engine until warm, change oil and filter again.
as for the rust, i would speculate that honed bores would only surface rust, but i don't know, someone chime in. _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
STEEL Member
Posted: Tue Apr 29, 2008 2:13 am Post subject: |
Xophertony wrote: | the froth is water that leaked past your rings (hopefully). change your oil and filter, run the engine until warm, change oil and filter again.
as for the rust, i would speculate that honed bores would only surface rust, but i don't know, someone chime in. |
I cant even afford to change the oil once right now, much less twice. You dont even know how poor I am right now.
Lets assume that the block and pistons are going to be ok, what about the valves, the carb, ect? Thats a brand new carb, I will cry if I killed it... |
Posted: Tue Apr 29, 2008 4:01 am Post subject: |
Carb should be fine.
I would be more worried if anything inside is damaged. I hydro locked my old v6. But I pulled the plugs, cranked several times. Left them out over night, put new plugs in the next night and ran like nothing ever happened. |
Posted: Tue Apr 29, 2008 4:56 pm Post subject: |
I really doubt you got enough water in the engine to do severe damage.
Check your plugs and dizzy cap. Could have gotten some moisture in there. _________________
Posted: Tue Apr 29, 2008 5:18 pm Post subject: |
Hydro locking a cylinder can f up more stuff than anything. Should have pulled the plugs before trying to force it to turn over. |
Posted: Tue Apr 29, 2008 6:00 pm Post subject: |
Time for a rebuild dude. |
mrpopo573 Member
Joined: 13 Oct 2005 Posts: 761 Location: Port Townsend/Maui HI
Posted: Tue Apr 29, 2008 6:52 pm Post subject: |
I second that. _________________
305302eater wrote: | Man I would love a 69. I hate you so much.
2000 Maxima SE 5 Speed VQ30
305 302eater Member
Joined: 18 Feb 2007 Posts: 604 Location: port orchard
Posted: Sat May 03, 2008 7:15 am Post subject: |
Twilightoptics wrote: | Time for a rebuild dude. |
I third that. Should have taken the plugs out and cranked the crap out of it to get the water out. _________________ Thirdgenless |
STEEL Member
Posted: Sat May 03, 2008 12:42 pm Post subject: |
Its running fine now. Oil change and some seafoam.
Had I been able to figure out that it wasnt cranking because of water in the cylinders, then i would have done that, i didnt make the connection.
I might still make it to cows. |
cameron7710 Member
Posted: Sat May 03, 2008 1:36 pm Post subject: |
STEEL wrote: | Its running fine now. Oil change and some seafoam.
I might still make it to cows. | good to here shes back to normal |
