Woot, new parts
PostPosted: Sun Apr 13, 2008 3:04 pm    Post subject: Woot, new parts Reply with quote
ok, so trip 4 hrs away to pick up some parts...
axle, GU5, G80, J65 all in one
booster, master cyl, prop valve
tpi cruise cable
3rd brake light
24mm swaybar
left front fender(needs some work, but better then what I got)
4th gen front seats, black. Option on rear seat later this summer.
2 sets of hood hinges with working struts(for a friend)
Time to get to work Twisted Evil
Does the 3rd gen posi need that special posi fluid like the 4th gen?
PostPosted: Sun Apr 13, 2008 3:56 pm    Post subject: Reply with quote
GM Limited Slip addative.
I only put in about 1/2-3/4 bottle.
The more you put in, the more slippery the gear oil becomes, the more the clutches slip, the faster your posi wears out.
Don't put enough in, and you'll chatter around a sharp corner, but doesn't hurt anything percay.
PostPosted: Sun Apr 13, 2008 5:10 pm    Post subject: Reply with quote
What size is the bottle you speak of. 1qt, 1pt, etc?
PostPosted: Sun Apr 13, 2008 5:31 pm    Post subject: Reply with quote
It's like... 8z
