Camaro350Z28 Member
Posted: Wed May 19, 2004 3:43 pm Post subject: Forgot to ask |
How hard is it too lower car if i buy the springs? i took it to les schwab but one of the struts is messed up so they didnt do it so now im gonna save money and do it myself, lookin to buy some struts and everything, whats involved in the lowering process any special tools?
Tim |
Posted: Wed May 19, 2004 5:55 pm Post subject: |
you need jacks/stands/spring compressor for the front.
Rear is a piece of cake.
Front struts are easy, springs are a BITCH! That's why my car is going to remain stock height. |
Camaro350Z28 Member
Posted: Wed May 19, 2004 6:29 pm Post subject: |
i thought i read in a magzine i can just get my springs compressed onto the strut itself by a machine shop?? is that right? im not sure on suspesion and how everything works under there, but if thats true i could pull out the old and easy replace all the new?? or is there somethin im missing? thanks paul
Tim |
Posted: Wed May 19, 2004 6:49 pm Post subject: |
| Camaro350Z28 wrote: | i thought i read in a magzine i can just get my springs compressed onto the strut itself by a machine shop?? is that right? im not sure on suspesion and how everything works under there, but if thats true i could pull out the old and easy replace all the new?? or is there somethin im missing? thanks paul
Tim |
Like "coil-overs"? I think you should buy actual coil-overs if that is what you wanna do. Art Morrison over in Fife sells them for 3rdgens. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Midnight Sun Member
Posted: Thu May 20, 2004 4:59 pm Post subject: |
You are gonna need some LCA's if you are doing this to a thirdgen.
At least that is what I think. I am trying to sound smart and Cheezx tried to explain it to me. But untill I do something myself, or you draw a picture, I am not going to understand.
But... My buddy lowered his S10, and changed out leaf spring for a 3-link in a Sonoma in 6 hours in his driveway. _________________
Posted: Thu May 20, 2004 5:05 pm Post subject: Check it out here... |
Follow this link: http://www.artmorrison.com/camaro.htm _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Camaro350Z28 Member
Posted: Thu May 20, 2004 5:46 pm Post subject: |
dont need lca's but i could use some, and relocation brackets for em too when lowerin car.. and no my thirdgen is lowered im doin this to my 4th gen, but its the same either way.
Tim |
Posted: Thu May 20, 2004 6:23 pm Post subject: |
| Midnight Sun wrote: | You are gonna need some LCA's if you are doing this to a thirdgen.
But... My buddy lowered his S10, and changed out leaf spring for a 3-link in a Sonoma in 6 hours in his driveway. |
How much was the 3 link for the S10? And was it an older S10? I gotta do something the s10 squats and doesn't get any traction. |
Gibby85 Member
Posted: Fri May 21, 2004 1:24 pm Post subject: |
Dude, I did my ROC myself. You really don't NEED spring compressors for the front, though they will make it so you don't have to drop the A-arm as well as the sway bar and strut. For the rear, you may want to get an adjustable panhard, though I don't have one and don't notice a difference in the way my axel sits from side to side. So, that's your call, like I said, I don't NEED it, though would like to have one. LCA's aren't needed either. One thing you will probably want to do, and especially if they are old and worn out is get some new shocks/struts. You'll be "pogo-ing" pretty severely if you dont. I just put in some KYB's (did that myself too) and love 'em. Just PM me if you any help dude. _________________
PonchoTA Member
Posted: Fri May 21, 2004 3:16 pm Post subject: |
| Gibby85 wrote: | | Dude, I did my ROC myself. You really don't NEED spring compressors for the front, though they will make it so you don't have to drop the A-arm as well as the sway bar and strut. For the rear, you may want to get an adjustable panhard, though I don't have one and don't notice a difference in the way my axel sits from side to side. So, that's your call, like I said, I don't NEED it, though would like to have one. LCA's aren't needed either. One thing you will probably want to do, and especially if they are old and worn out is get some new shocks/struts. You'll be "pogo-ing" pretty severely if you dont. I just put in some KYB's (did that myself too) and love 'em. Just PM me if you any help dude. |
Ditto on all, but would like to add that since you will be disconnecting the spindle from the lower A-arm, might as well press in a new ball joint too! They're not awfully expensive, and maybe throw in some decent bushings... etc.!
(I know all about "While-I'm-at-it-itis"!!)  |
Camaro350Z28 Member
Posted: Fri May 21, 2004 4:09 pm Post subject: |
hmm yeah i have to get struts so thats a must, gonna get shocks too along with springs so.. i would love to do it all myself save quite a bit of money.. just never done it before is all, im sure its not too hard... just wanna do it all at the same time, im not gonna do too much suspension to my 4th gen though right now, buyin all that for my 3rd gen so i can actually put my 400sbc to the ground. so as in lcas and everything those are goin to the 3rd gen but shocks and struts and springs will top off the 4th gen.. and some relocation brackets, ill let you guys know if im havin any troubles when i get started on it. thanks guys
Tim |
Posted: Sat May 22, 2004 1:25 am Post subject: |
| PonchoTA wrote: | | (I know all about "While-I'm-at-it-itis"!!) |
I HATE that! While I'm putting springs in, why not put all new bushings. Well, they'll have to align it anyways, why not new tierods, how about a new centerlink, how about adj. panhard, lower lca's, lca relocation....
Man, this stuff just goes on and on!  _________________
Midnight Sun Member
Posted: Sun May 23, 2004 2:47 am Post subject: |
| Twilightoptics wrote: |
I believe it was a 96, not positive.
He bought the kit from www.suicdedoors.com, and he paid a pretty heavy penny for them at the time.
Here is a link to there 3-links
http://www.suicidedoors.com/products/4linkkits.htm _________________
Posted: Sun May 23, 2004 6:37 pm Post subject: |
| iansane wrote: | ...Man, this stuff just goes on and on!  |
Word.
