Plans for my Exhaust
STEEL
PostPosted: Fri Sep 07, 2007 4:27 pm    Post subject: Plans for my Exhaust Reply with quote
Ok, I have never messed with exhaust systems before, but let me see if my train of thought is correct.
Buy headers and a Y-Pipe with 3 inch pipe, take it back to a cutt out pipe, but my question is:
If I install a 3 inch electronic cut out, then can I use some kind of a adapter and hook up the cat behind the cutt out?
I want to run the stock muffler, still run a cat, and hopfully leave MOST of that part alone, making it so the car is nice and enviro frendly and quiet when I aint driving hard.
please, details on how this could be done, I aint done anything with exhuast before![/img]
PostPosted: Fri Sep 07, 2007 4:42 pm    Post subject: Reply with quote
You will have to weld it yourself. Really the easiest place to fit a cut-out on our cars, is right where the cat is.
--John
jakemk8706
personally i say screw the environment. i have headers and a flow master exhaust w/o cat. and i still dont think its loud enough.
gas brake dip dip
PostPosted: Fri Sep 07, 2007 5:18 pm    Post subject: Reply with quote
Check into the emission laws where your car is registered. If you don't have to have a cateletic converter, get rid of it.
John (dewey316) has Hooker shorty headers, no cat, aftermarket Y-pipe, 3" exhaust pipe from the Y back, and a flowmaster (40 series? 80 Series?), and his car is pretty tame unless he's on it.
His car is an L03 just like yours. (albeit, his is modifed in a few more places)
PostPosted: Fri Sep 07, 2007 5:37 pm    Post subject: Reply with quote
Technically Chris, if your car came with a catalytic converter... by law you're supposed to have one. Emission required or not.
Pretty much any Header/Y pipe you buy... will need some sort of modification to get it to mate to the factory exhaust.
Your best bet is to buy a Header/Y pipe assembly.
Buy a Cat back assembly.
Then buy an exhaust cutout and have the cutout welded to the Y and the Catback.
