kurfbird Member
Posted: Sat Aug 18, 2007 8:29 pm Post subject: okay 3.1 has a bad head gasket. |
I was getting bubbles in the radiator and determined that I have a bad head gasket. Compression was 135-150 PSI.
Once I get the heads removed. How can I determine if my block is wraped or my heads are warped. I know to check for cracks. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
wanarunhard Member
Joined: 11 May 2006 Posts: 125 Location: ellensburg wa
Posted: Wed Aug 22, 2007 9:26 pm Post subject: heads |
I usally get a carpenters square the big metal one put it across the face and see if i can fit a feeler gauge between the head and the square |
