zz4 fastburn alum. heads...
jakemk8706
PostPosted: Wed Jul 11, 2007 5:06 pm    Post subject: zz4 fastburn alum. heads... Reply with quote
i was offered a pair of these today for 400 dollars. they are off a gm cratemotor that was intstalled on a boat. roughtly thirty hours on them...
should i buy?
gas brake dip dip
redlava
PostPosted: Wed Jul 11, 2007 8:40 pm    Post subject: Reply with quote
I dont know what your goals are, but since the heads are aluminum I would say its a decent price.
PostPosted: Thu Jul 12, 2007 11:08 am    Post subject: Reply with quote
Hell yeah. I've seen some awesome numbers with them. They are essentially aluminum Vortec heads that go in the $800+ range IIRC.
Yet they seem to put out more power than iron vortecs.
Tap that!
PostPosted: Thu Jul 12, 2007 11:13 am    Post subject: Reply with quote
Are they actualy fast burns, or are the ZZ4 heads? IIRC the "fastburn" heads are diffrent from the Alum Vortecs that the ZZ4 got. I will have to search for GM part numbers to verify though.
--John
jakemk8706
PostPosted: Thu Jul 12, 2007 4:39 pm    Post subject: Reply with quote
i was told they were zz4 fastburn heads...looked the id number up and it said they were 58cc. 1.94 int 1.5 exh. from what i hear these will also raise my compression ratio...btw i bought them last night.
gas brake dip dip
Mangus
1989 Pontiac Trans Am
PostPosted: Tue Jul 17, 2007 9:40 am    Post subject: Reply with quote
58cc?! Heck yeah they'll raise your compression ratio! Premium gas only!
PostPosted: Tue Jul 17, 2007 9:49 pm    Post subject: Reply with quote
You can use a .041 thick gasket and that will bring the compression down. Still use premium since you're quench wont be desireable.
Might have the head installed with bigger valves and turned into 64cc.
