Reverse lights?
PostPosted: Sun Jul 01, 2007 10:23 pm    Post subject: Reverse lights? Reply with quote
So at some point over the weekend of Cows, my reverse lights decided they wanted to stop working.
I'm thinking maybe I should get around to doing this.
I'll try bridging the wires together on the plug to see if I get lights...if not and it is the plug in the transmission:
1) How hard is it to get out (i.e can I just put a wrench on it and remove it)
2) Will I need to drain the fluid out of the trans first?
3) How can I test the switch to make sure its good (Use a DVOM?)
4) If the switch needs replaced, can it be found at any parts store, or will I have to go to the stealership?
I'll go test and report back.
PostPosted: Sun Jul 01, 2007 10:48 pm    Post subject: Reply with quote
well with the test wire on it, looks like its the switch in the tranny.
PostPosted: Sun Jul 01, 2007 10:56 pm    Post subject: Re: Reverse lights? Reply with quote
-Unscrews like anything else.
-No. Just check to see if the fill plug is higher or lower than the switch. If the plug is lower than the switch, you wont lose and fluid either.
-Set the DVOM to continuity. Depress the little ball on the end of the switch and see if there is continuity.
-Napa probably has them. Otherwise it should be the same T5 to T5 so a boneyard would have one.
PostPosted: Sun Jul 01, 2007 11:07 pm    Post subject: Reply with quote
looks like I"ll be pulling the switch tomorrow.
A little research on TGO says I should have another (Green?) wire going to my E-brake handle and I think I only have the ground right now.
I figure I'll do that at the same time.
Tony...I think I left my Wire strippers at your house though. I can't find them anywhere.
PostPosted: Sun Jul 01, 2007 11:20 pm    Post subject: Reply with quote
what do they look like? do you mean at my dads house? i could stop by tomorrow and take a look, i'll be going by there on my way to the stealership to get my banjo bolts.
PostPosted: Mon Jul 02, 2007 12:18 am    Post subject: Reply with quote
Confused
Might be different on a factory T5, but my auto only had two wires for the lights going into the shift switch: solid green and solid blue.
PostPosted: Mon Jul 02, 2007 8:23 am    Post subject: Reply with quote
Green and Blue wires out of the harness go to the the reverse light switch. The green wire does not go to the ebrake. There is only one wire IIRC that goes to the ebrake and that's a wire that grounds out when the lever is lifted, to complete the "BRAKE" light circuit.
PostPosted: Mon Jul 02, 2007 9:55 am    Post subject: Reply with quote
hmm....mine's always on and I have the thing wired in.....I can't find it even in the factory 1986 Body wiring diagram I found.
PostPosted: Mon Jul 02, 2007 10:19 am    Post subject: Reply with quote
Mine stays on periodically. Sometimes the contacts on the lever itself get funky. If i push my lever left or right it's intermittant on/off.
PostPosted: Mon Jul 02, 2007 11:42 am    Post subject: Reply with quote
chris, keep in mind the sensor on your prop valve can also turn that light on. unplug it and see if the light remains on.
PostPosted: Mon Jul 02, 2007 11:49 am    Post subject: Reply with quote
AH HAH!
He doesn't have a prop valve!
PostPosted: Mon Jul 02, 2007 11:51 am    Post subject: Reply with quote
fine, "combo-valve". Rolling Eyes
PostPosted: Mon Jul 02, 2007 12:27 pm    Post subject: Reply with quote
What? No I mean chris said he didn't have one at all. Prop/combo whatever the hell you wanna call it.
PostPosted: Mon Jul 02, 2007 12:50 pm    Post subject: Reply with quote
then how do his brakes work? the rears would lock instantly, he would trail brake, and hit all kinds of stuff. Shocked
EDIT
yeah, see he has one.
unless he has removed it for some reason.
PostPosted: Mon Jul 02, 2007 2:12 pm    Post subject: Reply with quote
Never looked directly at it. He said he didn't have one.
And it is called a Proportioning valve. Very Happy
PostPosted: Mon Jul 02, 2007 3:08 pm    Post subject: Reply with quote
you know, i was never real sure on that. i have been told that the stock units were referred to as a "combo valve" and the adjustable ones were called "proportioning valve". so they are all called "proportioning valve" then eh? good to know.
but yeah, without one you will have 50/50 brake pressure distribution. and since these cars are not at a 50-50 weight distribution, and since cars tend to transfer weight forward under braking that is not a good situation. you would end up backwards most of the time. Shocked
PostPosted: Mon Jul 02, 2007 3:25 pm    Post subject: Reply with quote
FUN!! Razz
PostPosted: Mon Jul 02, 2007 3:30 pm    Post subject: Reply with quote
Wink thats what the "e-brake" is for.
PostPosted: Mon Jul 02, 2007 3:31 pm    Post subject: Reply with quote
I don't think that's accurate. One of the common mods is to remove the insides of the propvalve so that your rear brakes get full pressure. THere is a spring that regulates pressure to the rear. Lots of people just remove the spring and get better back braking without being too biased to the rear.
Sellmanb
PostPosted: Mon Jul 02, 2007 3:32 pm    Post subject: Reply with quote
That one is a combination valve.
