Took out an aftermarket alarm, won't start
ore89iroc
New Member
PostPosted: Wed May 05, 2004 7:40 am    Post subject: Took out an aftermarket alarm, won't start Reply with quote
Yes, a f$ck-up it was, but I thought it would be simple so I removed the alarm and the car won't crank. I can turn the key all the way but the starter doesn't even crank. It's probably VATS? Anyone proficient at wiring? Confused
I'll post some pics this evening detailing where the alarm was patched into the steering column and in front of the fuse box.
Evil or Very Mad
Ore89IROC
'89 IROC-Z, 350cid, 700R4, mostly stock
PostPosted: Wed May 05, 2004 7:44 am    Post subject: Reply with quote
Chances are something didn't get hooked up right. the alarm probably had some sort of starter kill function. that is one possible issue. the other is VATS, if they set the alarm up to bypass vats somehow, then that is an issue, IRC even with an aftermarket alarm, vats still functions, since it is controlled in the computer, the computer is looking for the proper signal from the resister in the key.
when you turn the key to the 'On' Position, do you get gauge lights?
ore89iroc
New Member
PostPosted: Wed May 05, 2004 8:07 am    Post subject: Reply with quote
Yes, gauge lights, radio, headlights, etc. at the 'ON' position.
PostPosted: Wed May 05, 2004 10:19 am    Post subject: Reply with quote
look under the dash where you took the alarm out. Look for a fat yellow or orange wire. That is the ignition to starter wire. The alarm should have taped that and split it. You need to hook that back up.
ore89iroc
New Member
PostPosted: Thu May 06, 2004 7:12 am    Post subject: Reply with quote
That's the problem, spliced 'em back and cranks up! WoooHaaa, i was going thru withdrawls after just one day. Shocked
Thanks TT! If your in the Eugene/Springfield area, I'll buy you a few rounds! Very Happy
Now onto setting up manual control of my fans...
PostPosted: Thu May 06, 2004 7:16 am    Post subject: Reply with quote
Nope, The Young Jedi Master Paul, is not of the age to indultge in the frothy goodness known as beer.
PostPosted: Thu May 06, 2004 7:41 am    Post subject: Reply with quote
Yeah yeah, rub it in hoser~ Wink
Glad it was the easy fix!
BTW on your fans.... take the black wire on the relay.... tap into it.... (keep it factorty like) but run a wire from it into your passenger compartment... to a switch, then run the other side of the switch to any ground source.
That will control one of the fans. Not sure which wire you need to ground on the other relay. May also be black.
kidcamaro
PostPosted: Thu May 06, 2004 7:19 pm    Post subject: Reply with quote
im of age and i live near you so ill take them lol j/k. good to hear ya got the car goin again.
PostPosted: Thu May 06, 2004 7:58 pm    Post subject: Reply with quote
ummm, Unca Schultzy is the designated drinker for the young lad. I prefer ales, um i mean Paully prefers ales Cool
Cheers
Glad you got her going man.
