HSR vs weiand 6-71 blower
Wolffy
PostPosted: Thu Jun 28, 2007 7:13 pm    Post subject: HSR vs weiand 6-71 blower Reply with quote
just looking for opinions at this point, im hoping to build my 383 stroker next year & not sure which route to go with, keep my HSR or go w/ the 6-71? i know each has pro & cons and that is what im needing & build info for the block as well
either way the internals will be forged
if i go the 6-71 it will have low compression somewhere in the 7 or 8 range (but not sure yet)
if i stick w/ my HSR ill go high compression & i dont really want to turbo or procharge it, that route is pretty pricey & i already have a 6-71
plus the coolness factor is much better w/ it sticking outta the hood & i already have the street scoop, so ill just need a carb & maybe change the pulleys for whatever ratio (boost) i decide to end up running
i could recycle my Nitrous system ill just have to figure out a way to plumb it into the intake, as i was told w/ the 6-71 not to run an under carb adapter
so chime in folks, share w/ me your knowledge & opinions.
thanxs, Wolfy
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Fri Jun 29, 2007 9:23 am    Post subject: HSR Reply with quote
HSR is awesome, we are doing a build right now, see post, New Dart block.
But, IF we didn't have the HSR, I think we would go 6-71 Blower with MPFI
That would be cool. As well as the wow factor.
Big bucks anyway you look at it, as well as big horse power.
I want the wow factor but the kid wants it all under the hood.
When I build my car, if it ever happens (have to build a shop and a house 1st, if I survive that) yep its 6-71 for sure.
Scott
PostPosted: Fri Jun 29, 2007 12:36 pm    Post subject: Reply with quote
What is HSR?
PostPosted: Fri Jun 29, 2007 1:13 pm    Post subject: Reply with quote
QwkTrip wrote:
What is HSR?
Holley Stealth Ram.
izcain
9sec Club
PostPosted: Fri Jun 29, 2007 5:00 pm    Post subject: Reply with quote
NOS makes a spray bar plate that is perfect for the 6-71 system and will look awsome. nothing like boosted with a shot of gas! lol Very Happy
9.17 @ 148
