What day will you be able to attend? |
Friday the 22nd. |
71% |
[ 5 ] |
Satarday the 23rd. |
28% |
[ 2 ] |
Total Votes : 7 |
82camaro383 12sec Club
Joined: 11 Sep 2005 Posts: 117 Location: Pullman/Vancouver, WA
Posted: Thu Jun 14, 2007 12:12 pm Post subject: |
Any of those two days are good for me. I should have everything tuned by then. _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Fastest Time: 12.7sec @ 107mph |
Posted: Thu Jun 14, 2007 2:37 pm Post subject: |
Let's rock Friday. |
Posted: Thu Jun 14, 2007 3:43 pm Post subject: |
Hey Quasi, why don't you add a poll to see how many people can go on which day? By the looks of it we're not going to settle on only one. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Jun 14, 2007 11:13 pm Post subject: |
poll added
(finaly i get to use my moderator rights for something ) |
Posted: Fri Jun 15, 2007 12:48 pm Post subject: |
looking forward to it. See you guys there! Maybe we could do a little bracket racing within our own group? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
STEEL Member
Posted: Fri Jun 15, 2007 1:23 pm Post subject: |
wait, isnt this for NEXT friday? |
Posted: Fri Jun 15, 2007 2:21 pm Post subject: |
oh yeah, I was thinking Friday and looking forward to it, forget that it was for next Friday. My bad. Next Friday the gates open at 6pm _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Jun 15, 2007 8:06 pm Post subject: |
Friday 22nd is the day eh?
Cool.
I'll try to be there. I think I'll only be able to get one pass in and pray I don't loosen the oil pressure sender.....
lets see i I can blow my motor up! _________________
Posted: Fri Jun 15, 2007 8:08 pm Post subject: |
Quasi-Traction wrote: |
I'll try to be there. |
Dude! It's your event, you better be there! |
Posted: Sat Jun 16, 2007 1:44 am Post subject: |
i can make it friday |
Posted: Sat Jun 16, 2007 11:58 am Post subject: |
who else can be there friday? _________________
STEEL Member
Posted: Sat Jun 16, 2007 12:21 pm Post subject: |
ill be there! |
Posted: Sat Jun 16, 2007 2:09 pm Post subject: |
I'll be there both days.
Quote: | lets see i I can blow my motor up!Twisted Evil |
please don't make too big of a mess. you don't know how much of a pain it is to clean up someones leak down.
Yesterday we had some guy break after he launched and emptied his oil pan on the pad. It took us an hour soak it up with rags, torch all the oil off, then we had to grease sweep it, then VHT it again. Not fun. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Jun 16, 2007 8:08 pm Post subject: |
I'll try not to make too much of a mess.
I dunno if it will even pass tech. I hope it will. _________________
redlava Member
Posted: Mon Jun 18, 2007 8:47 pm Post subject: |
Is there a certain amount of rubber fuel hose you are allowed to have? I have 2 feet of it going from the hard line on the frame to the fuel pump. Then some more rubber hose mixed in with the metal line from the fuel pump to the carb. Would a dirt bike helmet be good enough or do I need to buy a special one? |
Posted: Mon Jun 18, 2007 8:57 pm Post subject: |
Can't be there Friday. Gonna go see The New Cars.
Have fun guys!
Posted: Mon Jun 18, 2007 11:37 pm Post subject: |
redlava wrote: | Is there a certain amount of rubber fuel hose you are allowed to have? I have 2 feet of it going from the hard line on the frame to the fuel pump. Then some more rubber hose mixed in with the metal line from the fuel pump to the carb. Would a dirt bike helmet be good enough or do I need to buy a special one? |
hmmm. You're not supposed to have any more than 12" of rubberized fuel line from tank to carb. So that'd be a no go. BUT, if you can't see it then we probably won't catch it. Let me tech you in if possible. And that's a "no" on the dirt bike helmet. Those are DOT approved but the helmets you need to use at the drag strip must be SNELL 2000 or newer. If you want to buy a new one go ahead or you could just rent one at the racetrack for $5. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Jun 18, 2007 11:54 pm Post subject: |
cover the rubber fuel line with wire looming. |
83Z28BlackBetty Bam-Ba-Lam
Posted: Tue Jun 19, 2007 10:37 am Post subject: |
only 12" from tank to carb?! there is more than that just coming out of the top of the tank to the hard line!
Guess i better get some braided lines before i hit the track this summer.
Posted: Tue Jun 19, 2007 4:32 pm Post subject: |
My LG4 car originally had much more then that under the hood. Right from the factory. I bet the line from the hardline to pump was 14" or better, and there was a return right along side it. |
