82camaro383 12sec Club
Joined: 11 Sep 2005 Posts: 117 Location: Pullman/Vancouver, WA
Posted: Tue May 22, 2007 2:21 pm Post subject: Transmission Help |
I was wondering how much fluid are you suppose to put in a TH350. Mine has been leaking ever since i have owned it, and I am thinking that i might have overfilled it. _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Fastest Time: 12.7sec @ 107mph |
Posted: Tue May 22, 2007 5:55 pm Post subject: |
Been a long time since I've owned an automatic. If memory serves, you check it when hot and idling in park. Other than that, just like checking oil except for adding only a pint at a time. _________________ 92 Camaro
Posted: Tue May 22, 2007 7:56 pm Post subject: |
| Capacity varies based on what type of cooler you have, what type of pan, how big your converter is, ect. How much do you think it's overfilled? |
Posted: Tue May 22, 2007 10:11 pm Post subject: |
| It's around 13-15qts from dry to full trans/converter. |
Posted: Tue May 22, 2007 10:25 pm Post subject: |
I'm not sure how overfilled it was. Just about the entire transmission was covered in fluid. I have a b&m pan that holds 3 extra quarts and i'm not sure how many inches the torque converter is. I've read on other forums that the size is based on the the internals. I measured the case and it was 13 inches. _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Posted: Wed May 23, 2007 9:40 am Post subject: |
Good possability if you have oil atop the case that it's coming out the vent tube.
Just check your level with the dipstick HOT in park while running. |
