Wolffy Member
Posted: Sun Apr 15, 2007 9:11 pm Post subject: car wont start |
ok heres the problem
drove & parked my iroc last Nov or so, went to start about 6 weeks ago, she turns over, but will not fire
if i spray starting fluid into the TB, she will try to fire up
so i added gas in case
checked all the fuses- good
replaced the fuel pump relay
checked to see if gas was pumping from the tank to the fuel filter - nothing comes out
checked the fuel pump, by hooking it to a battery, it pumped fuel
so what the heck is going on??
im kinda stumped at this point? |
90droptoproc Member
Posted: Sun Apr 15, 2007 10:28 pm Post subject: |
tank ground? _________________
Posted: Sun Apr 15, 2007 11:48 pm Post subject: |
just start from t he back and move forward. you have allready applied direct 12V to the pump and it worked, so the pump is good. you know the relay is good. so ground the relay to turn the pump, if it does not pump you have a busted wire, get the test light out and start hunting. do you have power at the relay? do you have power on the wire to the pump? are the grounds good?
do you have the wire diagrams for the electrical path all this stuff takes? |
BigDaddyVu 12sec Club
Posted: Mon Apr 16, 2007 11:58 am Post subject: |
| steering colum??? |
Wolffy Member
Posted: Mon Apr 16, 2007 6:05 pm Post subject: |
got it running
it was either and/or the fuel pump & relay
the only problem now is the fuel guage says its full & at most its got 10 gallons
thanxs guys |
LB985IROC Member
1995 Chevrolet Camaro Z/28
Posted: Wed Apr 18, 2007 6:56 pm Post subject: |
now you just need to get the tahoe going lol _________________ Cadillac of Bellevue
Retail parts sales
Posted: Wed Apr 18, 2007 6:58 pm Post subject: |
| I have a good bicycle for sale its a huffy |
LB985IROC Member
Posted: Thu Apr 19, 2007 4:30 pm Post subject: |
"hey boy is that thing a huffy!? thats a nice bike boy!" -Reese Bobby _________________ Cadillac of Bellevue
Retail parts sales
