car wont start
Wolffy
PostPosted: Sun Apr 15, 2007 9:11 pm    Post subject: car wont start Reply with quote
ok heres the problem
drove & parked my iroc last Nov or so, went to start about 6 weeks ago, she turns over, but will not fire
if i spray starting fluid into the TB, she will try to fire up
so i added gas in case
checked all the fuses- good
replaced the fuel pump relay
checked to see if gas was pumping from the tank to the fuel filter - nothing comes out
checked the fuel pump, by hooking it to a battery, it pumped fuel
so what the heck is going on??
im kinda stumped at this point?
90droptoproc
PostPosted: Sun Apr 15, 2007 10:28 pm    Post subject: Reply with quote
tank ground?
PostPosted: Sun Apr 15, 2007 11:48 pm    Post subject: Reply with quote
just start from t he back and move forward. you have allready applied direct 12V to the pump and it worked, so the pump is good. you know the relay is good. so ground the relay to turn the pump, if it does not pump you have a busted wire, get the test light out and start hunting. do you have power at the relay? do you have power on the wire to the pump? are the grounds good?
do you have the wire diagrams for the electrical path all this stuff takes?
PostPosted: Mon Apr 16, 2007 11:58 am    Post subject: Reply with quote
steering colum???
Wolffy
PostPosted: Mon Apr 16, 2007 6:05 pm    Post subject: Reply with quote
got it running
it was either and/or the fuel pump & relay
the only problem now is the fuel guage says its full & at most its got 10 gallons
thanxs guys
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Wed Apr 18, 2007 6:56 pm    Post subject: Reply with quote
now you just need to get the tahoe going lol
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Wed Apr 18, 2007 6:58 pm    Post subject: Reply with quote
I have a good bicycle for sale its a huffy
LB985IROC
PostPosted: Thu Apr 19, 2007 4:30 pm    Post subject: Reply with quote
"hey boy is that thing a huffy!? thats a nice bike boy!" -Reese Bobby
Retail parts sales
vee-six
