miamivice Member
1982 Pontiac Trans Am
Posted: Tue Apr 06, 2004 6:20 pm Post subject: wont start |
this post is regarding my 82 crossfire TA.........the dang thing wont start
when i turn the key nothing happens. doesnt even click. i tried jumpin the battery tonight too, nothing happened. there is no power to anything, not even the lights or horn work (and i checked the fuse, thats good). what could be the problem?
my guess is that it might be the starter, but what the heck do i know. any ideas?
thanks |
Posted: Tue Apr 06, 2004 8:20 pm Post subject: |
if theres no power anywhere you need to check the battery connections first. Then check the fusible linkes. They're the smaller wires that bolt on to the starter at the same place as the main battery cable.. Gently try to stretch these wires, if any of them stretch like rubber, it will need to be replaced. |
BigDaddyVu 12sec Club
Posted: Tue Apr 06, 2004 11:14 pm Post subject: |
I had that happen to me in my 84 t/a. What you need to do is jack up the car and check the wires to the starter to see if they have melted on your exhaust or wires been rubbing in metal. and you may check the fusable link attacted to the starter. That is common when someone changes out the starter and remove the metal heat shield conduit that protects the wires and forget to put it back on. |
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Wed Apr 07, 2004 6:07 am Post subject: |
Check and see if your brake lights work. If they do its the fuse link on the starter.
(At least thats what happened on the wifes 85, earlier years might be different) |
miamivice Member
Posted: Sun May 02, 2004 4:51 pm Post subject: |
i checked everything you guys said, and still nothing?
any other ideas.
thanks |
Posted: Sun May 02, 2004 4:57 pm Post subject: |
Did someone take out all your fuses?
Maybe your ignition switch is bad? |
Posted: Sun May 02, 2004 7:50 pm Post subject: |
Get a set of jumper cables and put the one black end on the negative terminal of the battery and the other black end on the engine. Like on the alternator bracket or something where it won't get tangled if the car starts. Sounds alot like a ground problem to me. |
miamivice Member
Posted: Sun May 02, 2004 8:26 pm Post subject: |
rjmcgee wrote: | Get a set of jumper cables and put the one black end on the negative terminal of the battery and the other black end on the engine. Like on the alternator bracket or something where it won't get tangled if the car starts. Sounds alot like a ground problem to me. |
just tried that, didnt work |
Posted: Mon Jun 14, 2004 3:11 pm Post subject: |
Just had the same problem on my jimmy today. Turned out to be the ground cable at the battery. You couldn't wiggle it, but it wasn't in far enough to engage right. Tightened it down and away I went. |
