Steering wheel's
305 302eater
PostPosted: Sun Mar 11, 2007 8:54 am    Post subject: Steering wheel's Reply with quote
OK so i have never removed a steering wheel before. This is one of the very few few things I have never done on a car. Was wondering if anyone had any advice. I know i need a puller to pull it off but how do you put it back on? I plan on taking my stock grandma wheel out and am swapping the one out of my "85 IROC. Any info will help, thanks.
Thirdgenless
PostPosted: Sun Mar 11, 2007 12:43 pm    Post subject: Reply with quote
You might need a wheel lock depressing tool.
It's really easy, once you get it off, you'll just slide the new one on and tighten the nut down.
305 302eater
PostPosted: Sun Mar 11, 2007 1:11 pm    Post subject: Reply with quote
Ok cool. wasn't sure if i was going to need to press it back on or what. Thanks
Thirdgenless
Sellmanb
PostPosted: Sun Mar 11, 2007 1:16 pm    Post subject: Reply with quote
If you're just swapping steering wheels I dont think you'll need the lock plate tool (unless 3rd gens are different from all the cars I've been yankin' wheels out of at work?)
A steering wheel puller will be a must. Just take the wheel cover off, undo the big nut in the middle, pull off the steering wheel w/ tool and voila. To "press" the wheel back on all you have to do is tighten the nut and it'll push it on for yah.
Sellmanb
PostPosted: Sun Mar 11, 2007 1:17 pm    Post subject: Reply with quote
also just noticed you have a '92. Dont 92's have airbags in the steering wheel? If so, you'll want to take out the airbag fuse before doing any of this.
305 302eater
PostPosted: Sun Mar 11, 2007 2:20 pm    Post subject: Reply with quote
Yes i do. I new about the fuse removal, just in case i am going to take it off the battery. Thanks guysjavascript:emoticon('Very Happy')
Very Happy
Thirdgenless
Nathan J
1986 Pontiac Firebird
PostPosted: Sun Mar 11, 2007 3:28 pm    Post subject: Reply with quote
ya just dont pull the fuse unhook the battery and wait atleast 10 to 15mins just incase there is any power remaining only takes a static shock to blow a air bag. also i havent used a steering wheel puller in years no real need for them, undo the bolt and a couple good wacks and the wheel comes off. do it all the time at work =]
86 firebird
383sbc
th350 t brake
4th gen rear soon 9in ford rear
305 302eater
PostPosted: Wed Mar 21, 2007 7:14 pm    Post subject: Reply with quote
ok got the air bag out. Now what should i do with it? I don't want it to go off.
Thirdgenless
PostPosted: Wed Mar 21, 2007 7:24 pm    Post subject: Reply with quote
As in storing the airbag? Hell, I've tossed mine around my room/garage/house for the last two years and it's never done anything. I'd say toss it where you want to.
PostPosted: Wed Mar 21, 2007 7:27 pm    Post subject: Reply with quote
you can make a sick whoopee cushion out of it.
PostPosted: Wed Mar 21, 2007 7:33 pm    Post subject: Reply with quote
http://videos.streetfire.net/search/airbag/0/ad9033b1-ca35-4488-b5d4-b256d08fd76f.htm
Shrug
PostPosted: Wed Mar 21, 2007 9:25 pm    Post subject: Reply with quote
Shrug
I see your air bag and raise you one less nut!
http://www.break.com/index/another_air_bag_explosion_under_nuts.html
PostPosted: Wed Mar 21, 2007 9:28 pm    Post subject: Reply with quote
that's not right
PostPosted: Wed Mar 21, 2007 9:36 pm    Post subject: Reply with quote
Sad No no no...
NHRA427
PostPosted: Wed Mar 21, 2007 10:02 pm    Post subject: Reply with quote
http://www.break.com/index/air_bag_explosion_under_nuts.html
PostPosted: Wed Mar 21, 2007 10:16 pm    Post subject: Reply with quote
Shocked
decimated.
since this is allready WAY off topic....
PostPosted: Wed Mar 21, 2007 10:40 pm    Post subject: Reply with quote
No no no...
izcain
9sec Club
PostPosted: Wed Mar 21, 2007 10:47 pm    Post subject: Reply with quote
lol thats just wrong haha
9.17 @ 148
305 302eater
PostPosted: Thu Mar 22, 2007 7:05 am    Post subject: Reply with quote
Laughing Thats funny cause i work at a grocery store.
Thirdgenless
PostPosted: Thu Mar 22, 2007 9:15 am    Post subject: Reply with quote
Thats funny wonder if you can use that in a spud gun
