BigDaddyVu 12sec Club
Posted: Sat Feb 10, 2007 2:08 pm Post subject: MSD mopunting? |
hey guys i wanna see pics where you mount you MSD boxes??? _________________
Posted: Sat Feb 10, 2007 2:15 pm Post subject: |
There was a post on this a little while back I thought?
Old OLD OLD picture but :
Posted: Sat Feb 10, 2007 5:47 pm Post subject: |
That seems to be a popular spot.
 _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Feb 10, 2007 6:18 pm Post subject: |
| It just seems to tuck in there so sweetly |
Posted: Sat Feb 10, 2007 9:37 pm Post subject: |
Do both of you have the weather striping at the backside of the hood to cowl area? Meaning, no water gets back there? _________________
Posted: Sat Feb 10, 2007 10:30 pm Post subject: |
Yeah, its still there. The box stays pretty dry. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Feb 10, 2007 11:42 pm Post subject: |
sweet _________________
Posted: Sun Feb 11, 2007 3:32 pm Post subject: |
There's the factory weather stripping on my hood. I had it for 3 years until the coil took it out. Sent it in for repairs, no water damage.
Works fine for me. |
82camaro383 12sec Club
Joined: 11 Sep 2005 Posts: 117 Location: Pullman/Vancouver, WA
Posted: Sun Feb 18, 2007 1:29 am Post subject: |
i just got my 6AL box, and i was wondering if when you guys mounted yours, did you use the vibration mounts? _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Fastest Time: 12.7sec @ 107mph |
scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Sun Feb 18, 2007 8:21 am Post subject: mounting |
We mounted ours inside the car next to the drivers right leg, much better than under the hood.
No problems, but we did have an intermittent ground problem that we fixed.
Ours is the digital one but if you do this you can put a different pill in for rev limit quick and easy, plus less dirt/vibration.
Scott |
Posted: Sun Feb 18, 2007 8:57 am Post subject: |
| Didn't use the vibe mounts. |
Posted: Sun Feb 18, 2007 3:13 pm Post subject: |
| I didn't use the vibration mounts either. Would have had to access the back of the fire wall or needed longer sheet metal screws to do it. |
izcain 9sec Club
Posted: Thu Feb 22, 2007 11:47 pm Post subject: |
This is where I mounted the 6AL, 2 Step, Timing Controller, and NOS Window Switch. _________________
9.17 @ 148 |
Posted: Fri Feb 23, 2007 1:16 am Post subject: |
wow. thing looks like the dashboard of a fighter jet. does that sticker say "WARNING: you touch anything and we will probably die" |
Posted: Fri Feb 23, 2007 1:31 pm Post subject: |
| Xophertony wrote: |
seriously, that looks scary
izcain 9sec Club
Posted: Sat Feb 24, 2007 2:12 pm Post subject: |
Seen many of those....a guy I used to be in class with has one like that on his toolbox. _________________
