fbird82 New Member
Joined: 31 Oct 2006 Posts: 14 Location: Emmett, Idaho
Posted: Tue Oct 31, 2006 5:26 pm Post subject: Swap 4-speed for th350 |
| Does anyone know if the crossmember and driveline from a 4-speed manual will fit when swapping to a TH-350? I have been told the driveline will work on a short tailshaft TH-350, but don't know if I can re-use my crossmember or not. |
Posted: Tue Oct 31, 2006 5:59 pm Post subject: |
You need the B&M TH350 conversion kit.
It has an adapter to mount to the stock crossmember as well as the adapter to mount the torque arm. You will have to get a piece from the deal though. Part number listed in the instructions and is based on which torque arm you have. |
fbird82 New Member
Posted: Tue Oct 31, 2006 6:08 pm Post subject: |
I have the Hurst kit, will that work? _________________ 82 base model Firebird. GM Performance Parts 350, TH-350, Edelbrock Performer 1406 carb, Performer EPS manifold, Heddman shorty hedders, Hooker cat back exhaust, CEE sfcs, etc... |
