Door Handles
Midnight Sun
PostPosted: Mon Mar 15, 2004 6:43 pm    Post subject: Door Handles Reply with quote
I think I have a pretty good idea on how to take them off. But could someone briefly describe removing the exterior doorhandles before I try it myself and end up breaking something.
Thanks
-Eric
PonchoTA
PostPosted: Mon Mar 15, 2004 7:34 pm    Post subject: Reply with quote
I don't remember all the details, but it does involve taking off the inner door panel. (duh!) Very Happy
It also involves taking off the operating rod, and there are 2 bolts that hold the handle to the door.
Make sure to either replace or at least clean the gasket. A little silicone on the rubber wouldn't hurt either.
Personally, I would spray rust preventative all over inside the door while I had the panel off too!
hth,
Paully
Midnight Sun
PostPosted: Mon Mar 15, 2004 10:51 pm    Post subject: Reply with quote
hth,
Paully
The whole door is getting repainted Very Happy
PostPosted: Tue Mar 16, 2004 8:06 pm    Post subject: Reply with quote
If you're painting the door dont go anywhere near it with silicone until afterwards. Silicone is the hardest thing to get off and absolutely no paint will stick to it.
Midnight Sun
PostPosted: Tue Mar 16, 2004 11:28 pm    Post subject: Reply with quote
Noted.
Between you and Paully... I should just give you guys the car when I am done. Thanks a lot.
