soft brakes?
Jess
Administrator
PostPosted: Thu Oct 05, 2006 8:15 am    Post subject: soft brakes? Reply with quote
Well I don't remember how the brakes felt before the car sat for a while, but now the pedal has to go in a ways before anything happens, what would cause this? Is it just time to bleed the brake's? Thanks guys.
'88 Formula
'95 Trans Am - Sold
'88 GTA - Sold
'89 Firebird V6 - Sold
izcain
9sec Club
PostPosted: Thu Oct 05, 2006 8:18 am    Post subject: Reply with quote
How long has the car sat? there are several problems that are possible. when a car sits for too long the brake fluid can become saturated and cause a mushy condition just a possibility. Pulling the tires off and taking a quick look will definitly eliminate some variables though. Also bleeding the brakes is cheap insurance as well.
9.17 @ 148
Jess
Administrator
PostPosted: Thu Oct 05, 2006 8:21 am    Post subject: Reply with quote
Better part of 3 years. Its been driven a few times durring that time, but for the most part hasn't moved.
PostPosted: Thu Oct 05, 2006 8:22 am    Post subject: Reply with quote
I would bleed the brakes, and get some fresh fluid in there. If anything, it is cheap insurance.
I do notice after driving other cars, that my camaro brakes do feel kind of funny also, there is amost a dead spot before the engage, much more pronounched than other cars. I honestly dont' recall if it was like that stock, I have had the big brakes on here for so many years, its hard to remeber what the stock brakes were like.
PostPosted: Thu Oct 05, 2006 12:29 pm    Post subject: Reply with quote
i agree with others.. pump all the old fluid out and add new. which will also bleed them.
everytime i have experianced soft brakes it was due to air in the lines.
PostPosted: Thu Oct 05, 2006 2:53 pm    Post subject: Reply with quote
I agree three. Very Happy Change out the brake fluid. Like izcain said, the brake fluid has likely taken on quite a bit of moisture which can cause those symptoms. I changed the fluid on my Aurora and it firmed up the pedal again.
izcain
9sec Club
PostPosted: Fri Oct 06, 2006 12:17 pm    Post subject: Reply with quote
Brake manufacturers usually say to change the brake fluid once every 3 years anyways so looks like your right at that point.
9.17 @ 148
PostPosted: Fri Oct 06, 2006 12:26 pm    Post subject: Reply with quote
hmmm... might have to do mine too.
