oil leaking
wanarunhard
PostPosted: Wed Sep 13, 2006 6:23 pm    Post subject: oil leaking Reply with quote
ok if the pcv was plugged would it push oil out the seals? such as oil pan seal? tell me what you guys think ok?
PostPosted: Wed Sep 13, 2006 6:52 pm    Post subject: Reply with quote
Um... it depends on the breathing setup. If the only breather you had was a PVC (no breather or anything on the other valve cover.) I think it might be possible... if you create positive crank pressure.
PostPosted: Wed Sep 13, 2006 7:45 pm    Post subject: Reply with quote
I've run into that a couple of times. Motor has to be in pretty crappy condition though as well.
PostPosted: Thu Sep 14, 2006 3:29 pm    Post subject: Reply with quote
I would expect that most the oil would enter the cylinders. I think the obvious problem is the most likely problem... you have a leaking seal that needs replacing.
PostPosted: Thu Sep 14, 2006 3:33 pm    Post subject: Reply with quote
I would think the breather filter would have to be in pretty crappy condition also. Even if the PCV isn't working, if the breather filter is letting air thru, you shouldn't create any possitive pressure.
PostPosted: Thu Sep 14, 2006 6:10 pm    Post subject: Reply with quote
Hmm.... wouldn't it seep past the rings and the dipstick before it built enough pressure to blow the pan gasket?
Edit: Just noticed QwkTrip's post. Embarassed
wanarunhard
PostPosted: Thu Sep 14, 2006 7:58 pm    Post subject: oil leaking Reply with quote
ya i thought so to but somebody was telling me this havnt seen the car yet so i dont know i thought didnt sound right to me
PostPosted: Thu Sep 14, 2006 8:30 pm    Post subject: Reply with quote
I used to have a supercharged Vette that produced 12 psi of boost. There was a vent line from the oil pan plumbed into the engine air intake but it didn't work all that well. When I stood on the throttle oil would spurt out of the dipstick tube and collect on the exhaust header. If I got caught at a stop light after a hard run smoke would pour out from under the hood. Sometimes people would figure my car broke down and try to take advantage of the moment to beat me. Well, they were wrong... and I'd wop 'em even harder. Very Happy
