Posted: Fri Jul 21, 2006 6:50 am Post subject: POSI/LSD |
| If anyone can help out that would be awesome. I have 4.11 gears in my garage that I want to put in, but I don't want to without some sort of traction control. Are drum axle, 3-series, LSD units hard to come by? I've been looking around for a long time and noone seems to have any for sale. If I can't find one soon I'll have to buy new. Any suggestion or offers? |
Posted: Fri Jul 21, 2006 4:28 pm Post subject: |
| For the posi unit drum or disc doesn't matter if that helps your search. Spline count on the axles matters though, if you have an 89 you could have 26 or 28 spline axles I believe. |
Posted: Sat Aug 19, 2006 9:39 am Post subject: |
| So it turns out I need a 26 spline, 3-series LSD carrier. |
Posted: Sat Aug 19, 2006 2:37 pm Post subject: |
What the hell is an LSD posi?
Like... you go auto cross and have hallucinations about posi? |
Posted: Sat Aug 19, 2006 2:55 pm Post subject: |
Ahh didn't realize LSD was an acronym for Limited Slip.
Limited Slip is a GM term  |
Posted: Sat Aug 19, 2006 2:56 pm Post subject: |
| Posi-tractrion is just a "GMism" for a clutch type Limited Slip Differential or LSD. there are three types of LSD; clutch, viscous and helical. |
Posted: Sat Aug 19, 2006 2:59 pm Post subject: |
| Xophertony wrote: | | Posi-tractrion is just a "GMism" for a clutch type Limited Slip Differential or LSD. there are three types of LSD; clutch, viscous and helical. |
And Torsen!^ Actually there are tons of different kinds of "posi/limited slip"
As far as I know "limited slip" is a GM term. Everyone else calls them positraction. Hense GM's additive called "Limited Slip Oil Additive." |
Posted: Sat Aug 19, 2006 3:07 pm Post subject: |
| Twilightoptics wrote: | | Xophertony wrote: | | Posi-tractrion is just a "GMism" for a clutch type Limited Slip Differential or LSD. there are three types of LSD; clutch, viscous and helical. |
WRONG!!!!
Posi traction is chevy's.
Limited Slip is Ford's
I really dunno, just wanted to yell at Paul.  |
Posted: Sat Aug 19, 2006 3:10 pm Post subject: |
Read the link....
| Quote: | Factory Names
In the 1950's and 1960's many manufacturers began to apply brand names to their LSD units. The most famous of these was Chevrolet's "Positraction". Since then, Positraction (often shortened to "positrac" or merely "posi") has become a genericized trademark for LSDs.
Other factory names for LSD's include
Pontiac: Safe-T-Track
Ford: Equa-Lock and Trac-Lok
American Motors Corporation: Twin-Grip
Mopar: Sure Grip
Ferrari: E-Diff
Fiat: Viscodrive |
Posted: Sat Aug 19, 2006 5:43 pm Post subject: |
| You do know that I could post on Wikipedia that the sky is red... and it'd be there.... It's not credited information |
Posted: Sat Aug 19, 2006 7:10 pm Post subject: |
| I know. But then again most everything on the internet isn't. |
Posted: Sun Aug 20, 2006 11:58 am Post subject: |
| my brother uses "limited slip" when talking about toyotas, BMWs and Nissans... i had always figured it was the "official" term. |
Posted: Sun Aug 20, 2006 10:08 pm Post subject: |
I always kind of figured that "limited slip" was just a generic term for anything that will have two wheels turning on any manufacturers car.
I always thought each manufacture had there own cute little name for it (IE, chevy: Positraction, Ford: Equa-lock, Mopar: Sure-grip.)
oh well.  _________________
Posted: Sun Aug 20, 2006 11:10 pm Post subject: |
| Quasi-Traction wrote: | I always kind of figured that "limited slip" was just a generic term for anything that will have two wheels turning on any manufacturers car.
oh well.  |
Me too. |
alloy T56 Elitist
Posted: Sun Aug 20, 2006 11:11 pm Post subject: |
Dang........when I saw the "LSD" thing I thougth I was having flashbacks to the 60's
LSD was the term for "Lysergic acid diethylamide" One of those "mind altering drugs we had back then. |
Posted: Mon Aug 21, 2006 8:18 am Post subject: ENOUGH BS |
Now that we all are on the same page...
Back to my post. Like I said before, I'm looking for some kind of traction control. The rear end in my car is a GM 10bolt that will accept 26 spline 3 series carriers. If anyone has anything that will fit back there I would greatly appreciate it if it was for sale. What I don't want is a 2 series commonly found on IROC's or other V8 cars. _________________ E30
Posted: Mon Aug 21, 2006 5:19 pm Post subject: |
| 2 series carrier is fine if you use a ring gear spacer. There about $40 - $50 . If you got a smoking deal on a two series it would be worth it. |
Posted: Tue Aug 22, 2006 6:53 am Post subject: |
I'm slowly learning about camaro axles...
A stock GM 10 bolt camaro axle is a 7.5" right, not 7 5/8"? I have a 2 series LSD at home, but I hadn't known it would work until I just found out the spline count are the same. I'm going to track down a spacer and get it. |
Posted: Tue Aug 22, 2006 1:08 pm Post subject: |
| blue89 wrote: | I'm slowly learning about camaro axles...
Make sure the spacer comes with bolts. Sounds stupid but the ringgear bolts are left hand thread 7/16's fine thread. You can not just buy them.
I got a "deal" on the first ring gear spacer I bought and figured I'd just run down to the hardware store and get some longer bolts.
BTW, I have a spacer for sale.
Just needs bolts.  |
