Holley stealth ram, LT1 Throttle body ???
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Wed Aug 09, 2006 10:30 am    Post subject: Holley stealth ram, LT1 Throttle body ??? Reply with quote
We have been looking at throttle bodies, I believe it say's to use an lt1 throttle body.
Is this correct?
If we do, will all the bells and whistles go into it? The ones off our stock throttle body? IAC, and stuff ??
Anything else we need to know if we go with a new 58mm lt1 body
thanks
Scott
PostPosted: Wed Aug 09, 2006 6:30 pm    Post subject: Reply with quote
No. The LT1 style needs a few other things to work and the throttle cable is different. There is a reason they list TPI and LT1 TB as different.
Get the TPI throttle body for your year style car. I don't know if the throttle cable is the same on TBI vs TPI within the same year.
