Posted: Tue Jul 18, 2006 8:35 am Post subject: 26 spline axle (FROM A DISC BRAKE REAR!!!) |
Just one for now.
Going to put gears back in it.
Get the Moser axles when I can afford it.
$2500 for a 12 bolt is way too far off with school in the way this year. |
Posted: Tue Jul 18, 2006 9:55 am Post subject: |
| You should make this a sticky so it's always on the top � |
Posted: Tue Jul 18, 2006 11:03 am Post subject: |
TecherB Princess B
Posted: Wed Jul 19, 2006 1:43 pm Post subject: |
| I have one at my parents house th matching one was a little broken as you recall. |
Posted: Wed Jul 19, 2006 1:44 pm Post subject: |
| I thought that the one we took out of your car, was a 28spline Bart? You are talking about the ones that were in the car from when you got the car from Paul, and it had the Zexel in it, right? |
TecherB Princess B
Posted: Wed Jul 19, 2006 1:45 pm Post subject: |
| that is right my bad well if you want a 28 spline..... |
Posted: Wed Jul 19, 2006 7:52 pm Post subject: |
| I've got a pair of 26 spline.. but theyre drum.. |
Posted: Wed Jul 19, 2006 10:43 pm Post subject: |
| rjmcgee wrote: | | You should make this a sticky so it's always on the top � |
lol Buttface.
Drum once seem to be a HAIR bigger than the disc flange and don't fit under the rotor without machining on a lathe... and that dept at school is closed for the summer LOL.
Can't drive in canadia without one!
Gonna hit the yards tomorrow and look. |
Posted: Wed Jul 19, 2006 10:45 pm Post subject: |
| does'nt brandon work at a napa with a machine shope? my local napa used to ahve one, then they moved and got rid of it.... fools. |
Posted: Thu Jul 20, 2006 7:52 am Post subject: |
Paul, if you don't come up with a Disc rear axle I can sweet talk my friend rob into letting me use his lathe to mill it down.
Besides, he owes me for taking the Turbo and the exhaust piping off that Volvo....  _________________
Posted: Tue Aug 22, 2006 6:58 am Post subject: |
I know this is an old thread, but I did the PBR 11.5" disk swap on my drum axle. The caliper bracket was rubbing on the disk by just a hair, so I had spacer's made. These spacers go behind the rotor and fit it perfectly in the center of the caliper bracket. I have an extra set if you want them. They are 10awg mild steel, and I've been running mine for a year without any problems. _________________ E30
Posted: Tue Aug 22, 2006 7:48 am Post subject: |
| Already got it taken care of but thanks. The problem is the drum axle stud flange is too large and wont fit inside the factory disc rotor. |
