newbie 4th gen running hot
JROB96Z286SPEED
New Member
PostPosted: Sun Jun 11, 2006 6:46 pm    Post subject: newbie 4th gen running hot Reply with quote
Wondering if anyone else is having this problem.... 96 z28 ... its running real hot after I have been sitting at stop lights... has new thermo... new orange coolant... doesnt run hot while driving... but when I'm at a light it may hit 3/4 on the temp guage like 230 or something... anyways I'm sure its not supposed to get that hot... ? any ideas?
Thanks,
Justin
"I can walk on water, but I stagger on alcohol."
PostPosted: Sun Jun 11, 2006 6:59 pm    Post subject: Reply with quote
Hmm..............usually if it climbs at stoplights but cools while going....that suggests radiator....
JROB96Z286SPEED
New Member
PostPosted: Sun Jun 11, 2006 7:27 pm    Post subject: Reply with quote
Thanks for the reply man... yeah I'm not really sure what to do its more irritating than anything... ... I love the maro... Just got it all washed, vacumned, and wiped down today... looks good clean... dont want to drive to work tommorow... good excuse to call in " sorry can't make it to work just washed the camaro dont want to get it dirty" haha doubt that one would fly...
PostPosted: Sun Jun 11, 2006 8:01 pm    Post subject: Reply with quote
Your fan working?
PostPosted: Sun Jun 11, 2006 8:05 pm    Post subject: Reply with quote
I would have to check the specs on the 4thgens. Most thirdgen cars, had a t-stat in the 190* range, and the fans didn't kick on until 220*-230*, so when sitting, it isn't uncommon to get that hot. You need to find out what temps the fans come on in your car. You car will likely heat up to the fan temp when the car is just sitting.
PostPosted: Sun Jun 11, 2006 8:55 pm    Post subject: Reply with quote
Is this a new thing? If it's been like that awhile, John is probably right, these cars all tend to run hot stock.
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Sat Jul 15, 2006 10:03 pm    Post subject: Reply with quote
due my 93 t/a does it a guy at work was telling me that all the 4th gens get hot will sitting in traffic but they waont overheat and as soon as your moving they cool off alot i think they just have poor air/cooland curculation at an idle not moving
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Sat Jul 15, 2006 10:23 pm    Post subject: Reply with quote
It's not lack of circulation that causes it to overheat at lights. Lack of cirulation causes overheating at high speeds. Low air flow is what causes overheating at lights.
Just ask the old-school Mopar guys about that one. Wink
LB985IROC
PostPosted: Sun Jul 16, 2006 9:21 am    Post subject: Reply with quote
well yea i meant poor airflow through the engine bay
Retail parts sales
vee-six
PostPosted: Sun Jul 16, 2006 10:45 am    Post subject: Reply with quote
My friend had a cooling problem with his 00 t/a the radiator is at a tilt and with the condensor on the front of the rad is possibly plug up with road debris it sucks it up from the road so clean between the rad and the condesor.
PostPosted: Sun Jul 16, 2006 11:41 am    Post subject: Reply with quote
Had to clean mine when I did the engine swap. Had road debris about 1/4 of the way up between condenser and radiator. Still approches 230* sitting in traffic, but when the fan comes on it cools down to about 200*. Cruising sees about 190* and loaded (i.e. climbing hills) approaches 220*.
PostPosted: Sun Jul 16, 2006 12:15 pm    Post subject: Reply with quote
LT1 cars run hot. They use a revearse flow cooling system that cools the cylinder heads first and then the engine block. Didn't work that well. They will overheat on a hot day. Best thing to do is make sure you have a nice and clean radiator. Keep it clear of debris and dust. You can also add a new fan switch that will turn on the fans earlier than stock. This will also help.
One time in Chicago I was stuck in standing traffic in 100 degree weather. My '94 Vette convertible began to overheat. I had to turn the heat on full blast to keep going. Very very miserable time with the top down, sun beating on me, and the heater on full blast with pavement temps well exceeding 100 degrees.
PostPosted: Sun Jul 16, 2006 1:15 pm    Post subject: Reply with quote
You can also run a cooler t-stat, expecially if you chip it. My IROC has a 180* and a chip, and it never has ever gotten above 200*.
PostPosted: Sun Jul 16, 2006 2:46 pm    Post subject: Reply with quote
Cooler thermostats don't necessarily work well with LT1 cars. Do that as a last resort.
PostPosted: Sun Jul 16, 2006 3:02 pm    Post subject: Reply with quote
Doh! My bad. I'm forgetting about the LT1's goofy cooling system. I skimmed your first post, and missed that part completely.
