BigDaddyVu 12sec Club
Posted: Mon Jul 17, 2006 10:30 pm Post subject: what I did |
well i had installed my orignal axel rebuilt with 3.73 and eaton posi, bought new tires cooper cobras with the raised white lettering facing out (going for the era correct look), also installed a new holley 670cfn avenger. Its kinda squirlly around turns the posi really makes the tires bark. the holley seems to have a consistant and smooth power. may need a spare tranny t-5 world class if i could find one. _________________
Posted: Mon Jul 17, 2006 10:31 pm Post subject: |
Sounds like some nice upgrades. Was it an open diff before or did you just blow it up? Which car?
Posted: Tue Jul 18, 2006 5:33 pm Post subject: |
I blow up the orginal 3rd member and been using a 3.53? posi disc. i decided to have the orginal axel to be rebuilt with motive gear ring and pinion and eaton posi. _________________
Posted: Tue Jul 18, 2006 5:34 pm Post subject: |
BTW i am using the "royal purple" systhetic 75w90 lube with limited slip additive _________________
Posted: Tue Jul 18, 2006 8:31 pm Post subject: |
| BigDaddyVu wrote: | | BTW i am using the "royal purple" systhetic 75w90 lube with limited slip additive |
I just bought some of that because it was a dollar cheaper than mobil 1. You like?
I got my two quarts for $13  _________________
Posted: Thu Jul 20, 2006 5:44 pm Post subject: |
i like it. alot of racers uses that oil and haven't heard of anyone having problems with it. and it was sudjested by the shop that rebuild my axel. _________________
Posted: Thu Jul 20, 2006 9:14 pm Post subject: |
i installed a new holley mech. pump(80gph @ 7.5psi) today to help feed the power demands of my right foot. _________________
