Posted: Tue Jun 20, 2006 6:57 pm Post subject: Headlights... |
Next project...
Need at least one (preferably both) headlight assemblies from 88-98 C10 Pickup or Tahoe. Need to see what fabrication might be necessary to mak these fit before I get a brand new set. I'm looking for the ones with the projector low beam. _________________ 92 Camaro
Posted: Fri Jul 21, 2006 6:52 am Post subject: |
Are you trying to do the one piece dual headlight setup? There's a guy on vancouverfbody with this mod, looks different. |
Posted: Fri Jul 21, 2006 8:04 am Post subject: |
That's the plan, looks like I may also need a header panel that I can hack up to make these fit/work. So far this is just an idea from some pictures I've seen. Not in a big rush to do this yet. |
Posted: Fri Jul 21, 2006 12:22 pm Post subject: |
You don't like the offset lights? Or are you just trying to be unique? |
Posted: Fri Jul 21, 2006 1:07 pm Post subject: |
Just unique |
Posted: Fri Jul 21, 2006 6:16 pm Post subject: |
Those are the style I've had my eye on. Don't want to spend that kind of money until I know for sure I can integrate them into the header panel. |
Posted: Fri Jul 21, 2006 6:44 pm Post subject: |
Did you check to see if he is willing to sell the lights sepperatly? |
Posted: Wed Jul 26, 2006 3:12 pm Post subject: |
None yet, haven't been out to look for anything I can use. Still need to see if I can pull a header panel at the airport wrecking yard next time I get out there. Was the only place I've been to that had some 3rd gens without alot of front end damage. |
