wanarunhard Member
Joined: 11 May 2006 Posts: 125 Location: ellensburg wa
Posted: Wed Jul 05, 2006 9:02 pm Post subject: white trash louvers for camaro |
| white trash louvers for camaro black three peice with third brake light on top 40.00 plus shipping |
Posted: Wed Jul 05, 2006 9:09 pm Post subject: |
lol  |
Danked Banned
Posted: Thu Jul 06, 2006 9:14 pm Post subject: |
steve, these are for the back, am i correct? if so, bring em down when u come pick up my car and ill buy maybe, pm me _________________ Towed amaro, 2nd engine blown spent $1500 not spending more. Decided not worth it. |
Posted: Thu Jul 06, 2006 10:23 pm Post subject: |
The proble is that if they have a third brake light gap on top, it might look even worse than it normally would.  |
wanarunhard Member
Posted: Fri Jul 07, 2006 1:55 am Post subject: you bet guys |
yep real white trash and maybe air shocks and tires sticking out too  |
Danked Banned
Posted: Fri Jul 07, 2006 6:08 pm Post subject: |
Be careful with those, you might scrape your pimpin' exhaust system on the ground and accidentally take out your tranny along with it.  |
Posted: Sat Jul 08, 2006 11:00 am Post subject: |
Back in the day when air shocks and lifted back ends were actually cool.... a friend of mine jacked up his 71 malibu with them and stuck some wide 50s out back. During a race at lunch he had one of the lines blow out..or maybe it was the shock.. but anyway the air went out and the fender lip cut the tire. Car spun 180 and hit a ford truck ass to nose. Malibu traveling 80+ , ford 60...It peeled the malibu off the frame all the way to the back seat. The people in the ford ended up in the hospital for 2 weeks. My friend in the malibu was fine. When he built his next malibu he used 2" coil lifts instead of air shocks. I later bought that car, its the blue one I wrecked.
Also I havent really looked at where the shock mounts are, but without a frame under these cars its bolted to sheetmetal. The shock mounts arent designed to hold weight like they'll have to with air shocks. |
wanarunhard Member
Posted: Mon Jul 10, 2006 12:39 am Post subject: airshocks |
| guys air shocks werent meant to jack cars up they were for just keeping it level not a lot of weight just stffer in the corners peolpe jacking them up were abusing them lotts guys i know are just trying to stiffen ride not lift whole car to sky i like lowered cars myself wide tires and big engines ya know sleepers we called em |
