What is going to cause a steep dropoff in mileage?
PostPosted: Fri Apr 28, 2006 6:59 pm    Post subject: What is going to cause a steep dropoff in mileage? Reply with quote
I've noticed that it seemed like the car was going through a hell of a lot of gas lately, so over the last week I tallied up my fuel spent and mileage. Came up with this:
15.2 gals (10.3 Plus, 4.9 Premium)
196.5 miles, mostly around town, 35~50mph 2K~3.5Krpm
For those of you without calculators, that comes out to just under 13mpg. And if you think that's bad, it gets worse: I have 3.73 gears out back, and so my odometer is off by about %10. Which puts actual mileage more in the range of 10-11mpg. I had never checked the mileage before, but I am sure it wasn't that bad.
Specs:
1987 IROC
5.7L TPI V8 (L98)
Rebuilt TH-700R4 w/2000 RPM stall and fluid cooler
4th-gen aluminum driveshaft
3.73 Borg Warner
K&N's w/Airfoil
Headers w/custom exhaust
A/C & AIR delete
Low-temp thermostat (usually around 180* less on the freeway, more around town never below 170* or above 200*)
Hypertech Chip (yeah, yeah)
I know it has a AFPR on it, but without a gauge, I can't test that. It's not throwing any codes at all, and it's running as good as it ever has. I decided to swap out all the plugs while I'm replacing the header gaskets anyway. Next day off I get I'm going through and checking all the wires and the cap/rotor.
There is another thing that's bugging me though: Lately whenever I fill up, the gas tank seems to have a lot of pressure in it when I take off the cap. It didn't do this when I first bought the car, which is making me think possibly that something is wrong with the charcoal evap canister. I know that those do tend to boost mileage a tiny bit (due to a little excess gas getting dumped in) but I can't imagine that much of a difference due to just that problem.
PostPosted: Fri Apr 28, 2006 9:11 pm    Post subject: Reply with quote
Nice to meet you today man! How much did you end up paying for that gasket? Should've waited for me to ring you up. Smile
On topic; I know on my old 87 when the 02 started going out I ended up getting like 120 miles to a tank (on a 12 gallon fillup, never really put more than that in). Once I swapped that out mileage shot back up to 190-220 a tank.
They aren't too much, about 18 bucks.
PostPosted: Fri Apr 28, 2006 10:06 pm    Post subject: Reply with quote
Gasket was $10.99. Ended up paying $30 for that and a set of Bosch Platinums. Is it possible for an O2 to go out without throwing a code? When the one on my Ford blew out it sent all kinds of codes at me.
PostPosted: Fri Apr 28, 2006 10:10 pm    Post subject: Reply with quote
My 87 never threw a code. It was just giving shitty info.
I've heard NGK plugs working well in our cars from a few guys that stop in. Confused No idea.
kurfbird
PostPosted: Fri Apr 28, 2006 10:11 pm    Post subject: o2 sensor Reply with quote
Yea it possible.
Most of the time you wont get a code. They recomeded that you replace it like every 30,000 miles.
Me EGR went out on my 92 350 and never got a code just got a surge while crusing.
A buddy of mine told me that by the time you get a code the car willl just about not run.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Fri Apr 28, 2006 10:18 pm    Post subject: Reply with quote
If it's as cheap as you say, I'll just pick one up. When I replaced the one on my Ford, it cost me over $50, plus another $15 for the damn tool to get it off, since Ford decided to put it in a place physically impossible to reach with a wrench. Rolling Eyes
Is the O2 bung in the header itself, or is it farther down in the pipe?
PostPosted: Fri Apr 28, 2006 10:24 pm    Post subject: Reply with quote
Nice iroc by the way.
It'll be driver side manifold, just above where it bolts to the y-pipe.
PostPosted: Fri Apr 28, 2006 10:29 pm    Post subject: Reply with quote
Cool. If it's as cheap as you say, and you guys have it in stock, I'll swing by after work tomorrow and pick one up. I might as well kill all three birds at once when I pull off the headers.
BTW, thanks. My car needs a wash job bad though. I just cleaned it last week, but with this weather it's starting to look like an Arizona car. Rolling Eyes
PostPosted: Fri Apr 28, 2006 10:33 pm    Post subject: Reply with quote
Are you putting shorties on?
PostPosted: Fri Apr 28, 2006 10:38 pm    Post subject: Reply with quote
No, pulling them back off to replace the gaskets, then I decided while I had them off I would replace my plugs (Edelbrock's, so that's the only way to get at the plugs), and now I figured I might as well do this too.
PostPosted: Sat Apr 29, 2006 12:15 am    Post subject: Reply with quote
you actualy hafta yank the headers to replace the plugs? Shocked and i thought my SLPs were bad. i have to use a cut socket w/box wrench on 4 of them, box wrench on two and on the last two i can use a real spark plug socket and wratchet driver. i also run acell shorty plugs now.. which i can say made no change to the ease of plug changing. keeps the wires about a half inch farther from the headers though... think i'll run the delcos again next time.
ian i think i am going to replace my o2 sensor next time i am under the car. sounds like a plan.
PostPosted: Sat Apr 29, 2006 12:18 am    Post subject: Reply with quote
You using the r44lts plugs?
Should be able to get the 02 from up top... Confused Might be different with headers.
PostPosted: Sat Apr 29, 2006 12:20 am    Post subject: Reply with quote
i don't know what that means... i still have the box if you want a part number or somthing.. but they knew what i was talking about at the counter.
with the SLPs it is WAY easy to get from the bottom.
PostPosted: Sat Apr 29, 2006 5:41 am    Post subject: Reply with quote
I can get a few plugs, but there are some that you cannot even get a socket over.
PostPosted: Mon May 08, 2006 5:32 pm    Post subject: Reply with quote
Well, after swapping out the pligs (needed them bad) and the O2 sensor, the Camaro is running better than ever, but still drinking more gas than a three-ton Ford.
I belive it has an AFPR (small screw on top of the regulator between the rails, right?). Assuming it does, I was looking around TGO and eBay, and I'm thinking about picking up something like this:
http://cgi.ebay.com/ebaymotors/AUTOMETER-CARBON-FIBER-FUEL-PRESSURE-GAUGE-4712_W0QQcmdZViewItemQQcategoryZ6763QQitemZ8061047423QQrdZ1.
(Ian, I think that's something along the lines of what you're running on your HSR.)
Is it a good idea (or even possible) to just run the gauge of the valve on the rail, or am I going to need a hose and bracket to mount it?
Edit: Apparently that BBcode trick doesn't work here. Don't mind me. Embarassed
PostPosted: Mon May 08, 2006 6:17 pm    Post subject: Reply with quote
You can't really run that style right off the fuel rail. I didn't think about that when I bought mine thougt; I was going to mount it inside but decided against having a fuel line into the cockpit. Smile
Check this one out.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D800260&N=0&autoview=sku
$16.00 and you can mount that directly to the rail.
If you don't want to wait for shipping I picked up something similar at Grainger (sp?) in fife when I had TPI.
PostPosted: Mon May 08, 2006 6:35 pm    Post subject: Reply with quote
Nice. I used to work just down the road from that place.
Is it generally a good idea to leave it on the rail permanently? Seems like it would be an easy way to snap off a Schradder (sp) valve.
PostPosted: Mon May 08, 2006 10:37 pm    Post subject: Reply with quote
On my old TPI unit I think I actually pulled the schrader valve out so it was an open threaded hole and just threaded the old liquid filled guage I had straight into the the fuel rail. I'm pretty sure that's how my buddy is still doing it. (He put the TPI unit on a 350 and dropped it in an 86 cherokee)
PostPosted: Thu May 11, 2006 9:25 pm    Post subject: Reply with quote
Actually, on that intake, there are two vacuum connections dirrectly above the schrader valve (one is actually the AFPR line), so I'm going to have to go with a 90* connection no matter what gauge I use. Bashy Bashy
PostPosted: Thu May 11, 2006 10:00 pm    Post subject: Reply with quote
That guage is pretty small, 1.5" tall overall, I think it's got it's fitting in the back for just such an application.
