Serpentine conversion parts
PonchoTA
PostPosted: Fri Apr 14, 2006 7:58 pm    Post subject: Serpentine conversion parts Reply with quote
Hi guys,
I'm looking to get all the brackets and pulleys for a serp. conversion on my traditional SBC. I will be getting new components (water pump, alt., PS pump, etc.) but the appropriate part numbers would be very handy, for comparison purposes anyway, and a description of the correct bolts in which position hole so I can get new ones.
Hoping to not have to spend a lot, but would like the brackets, etc. to be in good shape, as I will be polishing them!
Anyway, if you have some or all of these, please let me know! I have no smog pump so that won't be an issue either. Very Happy
My idea is for the PS to be mounted on the driver's side, and the alt. on the pass. side. Hopefully, the brackets you have will account for that. Eventually however, if I can get an aftermarket A/C system worked out, that will be high on the pass. side, the PS high on the driver's side, and the alt. low on the driver's or pass. side, whichever works out best.
Thanks a lot!
Paul
Paully
