Hinge
PostPosted: Tue May 09, 2006 9:05 pm    Post subject: Hinge Reply with quote
I need a passenger side lower hinge. Anybody have one? If so are you coming to cows?
PostPosted: Tue May 09, 2006 9:56 pm    Post subject: Reply with quote
i could pull one at the yards for ya.
PostPosted: Tue May 09, 2006 10:18 pm    Post subject: Reply with quote
I need both sides done, especially the driver's door, sags a bit when opened and movement isn't smooth anymore. Really chewing up the top edge of the GFX when the door opens/closes. I'm hoping it's the pins and bushings.
PostPosted: Tue May 09, 2006 10:30 pm    Post subject: Reply with quote
I actually looked into this a bit when I first bought my car, since the drivers door is pretty crapped out. However replacement pins go for $75 per door. The problem is that every JY door I've ever seen is as bad, or worse, than mine. Rolling Eyes
PostPosted: Wed May 10, 2006 4:58 am    Post subject: Reply with quote
.......just like your 2.8L brandon.........I had an extra door that had a huge dent in it, hinges were in pretty good shape..........but its been gone for a couple months now. Rolling Eyes
I don't think the lower hinge unbolts from the door, I don't know if brandon wants the pin with the roller bushing and the spring but you might have to Sawzall the whole hinge off the door.....
PostPosted: Wed May 10, 2006 6:10 am    Post subject: Reply with quote
I don't feel like running out and checking right now, but I belive that Chevy bolted the hinge to the door, and welded it to the body. So bring your torch, Tony. Wink
PostPosted: Wed May 10, 2006 8:44 am    Post subject: Reply with quote
other way around. Welded to the door, bolted to the body. This is why its a 'removable' body pannel. Wink
PostPosted: Wed May 10, 2006 11:04 am    Post subject: Reply with quote
screw that. all i have is one of those "burnsomatic" pieces of crap. that would take eons.
kurfbird
PostPosted: Wed May 10, 2006 11:05 am    Post subject: Hinge bushings Reply with quote
You can get hinge bushings at any auto store. Shucks has them for sure. Replaced mine on my 92 works great. Diffently saves you some time and money. Only runs like 5-10:00 fior the lower bushing kit.
TDS has them but I guess they are expensive. Look on TGO tells you how to do the repair.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Wed May 10, 2006 11:52 am    Post subject: Reply with quote
Doh!
Yeah, TDS wants $75 for each kit. I have yet to hear a bad review of the kit itself, but I don't have that kind of bank to throw around.
PostPosted: Wed May 10, 2006 11:53 am    Post subject: Reply with quote
The TDS kit and the Napa bushings are different things.
If you look at the hinges, there are pin and bushing hinges and then fixed hinges. The top hinge is usually the culpret and requires the kit.
kurfbird
PostPosted: Wed May 10, 2006 12:13 pm    Post subject: I hear that its the lower bushing that wears out. Reply with quote
I hear and that is what was bad on mine. It normally the lower bushing. I even picked one upon ebay for 8.00 Check TGO forsure. I just didthe lower bushing and it fixed my problem. If it works for less than 10.00 dollars. Your good. If its the upper youw ill know at that point.
Also have soemone lift upand down on the door and look at the lower pin. That is where the wear is it. If you see slop then you need the bushing kit.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Wed May 10, 2006 12:26 pm    Post subject: Reply with quote
I've seen many bad lower bushings. Replaced them, and had it better, but not fixed. It was always the top hindge that needs to be drilled out.
This was on 3 different maros.
PostPosted: Wed May 10, 2006 1:58 pm    Post subject: Reply with quote
He's right. Really the top hinge has the least support with just the bushings. I've seen the regular parts store kits, they're ok. I'd rather pay the $75 and get the one from TDS or Year One (they're the same). Xophertony used it and it put the door on his old bird back to factory alignment. The Extra $ for the quality part is often worth it to avoid the headache or the cheap replacement not working right.
PostPosted: Wed May 10, 2006 2:00 pm    Post subject: Reply with quote
You'd be better off using a battery powered sawzall and cutting part of the door skin and then worry about cutting the rest off later.
PostPosted: Wed May 10, 2006 4:59 pm    Post subject: Reply with quote
My upper hinges seem to be OK. I don't care if I have to rebuild the replacement hinge either. Beings its the lower one its the cheap one to build. The door holder roller is totalled out on my hinge. so thats the half I need.
kurfbird
PostPosted: Wed May 10, 2006 6:22 pm    Post subject: Hinge Reply with quote
I can get the roller half from my parts car. That is the part thaat bolts on the car. What side do you need
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Wed May 10, 2006 7:28 pm    Post subject: Reply with quote
Odd thing is I need the passenger side. Drivers side is still OK, with 270k miles on the clock.
