Posted: Fri Feb 20, 2004 8:26 pm Post subject: Oil Pressure (when is too much too much)? |
So right now cold I have 55psi and hot it's about 35-40psi. It jumps to around 50psi when I spin her higher, but soon to be shifting just shy of 7000rpm.... is 50psi gonna cut it?!
Some of the pressure springs I've seen to install give me like 85psi cold and 60psi hot!? |
Posted: Sat Feb 21, 2004 4:24 pm Post subject: |
55 is probably fine since you wont be sustaining 7000 rpm for long. The standard has always been 10psi for every 1k rpm though. |
