kidcamaro Member
Posted: Fri Feb 20, 2004 3:26 pm Post subject: question about fuel filters. |
i have heard that to change my fuel filter on my car i need to depressurize the system. is that true and how do i do it? |
Jess Administrator
Joined: 24 Nov 2003 Posts: 425 Location: Mount Vernon, WA
Posted: Fri Feb 20, 2004 5:05 pm Post subject: |
I don't know, I just jacked my car up - pulled out the old one and put in the new one |
PonchoTA Member
Posted: Fri Feb 20, 2004 5:39 pm Post subject: |
The easiest way to relieve the pressure on those cars is to pull the fuse for the fuel pump, start the car, and let it run out of gas. The system will be purged.
After replacing the filter, replace the fuse, and start the car. It will take a few extra seconds because you have to prime the whole fuel line, but it's relatively painless, and less messy this way.
IIRC, the manual also mentions this... even the cheap ass Haynes manual. |
Demon 12sec Club
Posted: Fri Feb 20, 2004 5:53 pm Post subject: |
I think the only reason it says anything about de-pressurizing is because if you don't you'll just have some gas leaking out of the lines when you do it, nothing a golf tee wouldn't fix if you drop something or need to go hunt for something after pulling the old one ;) |
kidcamaro Member
Posted: Fri Feb 20, 2004 9:31 pm Post subject: |
well i have a manual but sort of misplaced it during my time of mourning while replacing my heater core. i need to find it i guess. lol |
Project_1986_TA Member
Posted: Sat Feb 21, 2004 12:33 am Post subject: |
If its fuel injected there's a shrader valve on the passenger side on the fuel rail. it has a black cap on it, just unscrew and release the presure. Fuel will come out so have a rag handy. After that just make sure everything is off and remove the old, and install the new. If its on a carbed car i dont know, i would go with Paul and run it out of gas. Good luck! |
widow_maker89 New Member
Posted: Sun Feb 22, 2004 7:15 am Post subject: |
my cap is aluminum colored not black.....eother way is efficient. The problem isnt leaking fuel while you change the filter the problem is the 55 psi initial shot that goes in your eyes if you dont depressurize the system... not a problem for you TBI guys |
