no fuel
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Sat Feb 25, 2006 11:00 am    Post subject: no fuel Reply with quote
hey guys trouble again my car wont start no fuel checked for fule used startign fluid and such replaced the pump relay and the fuse but npthing is there anythgin else on one of these cars that can cause pump failure besides the pump going out?
Cadillac of Bellevue
Retail parts sales
vee-six
Sellmanb
PostPosted: Sat Feb 25, 2006 8:48 pm    Post subject: Reply with quote
Do you hear the pump kick on even?
I need a refresher on your car specs, sorry.
PostPosted: Sat Feb 25, 2006 10:41 pm    Post subject: Reply with quote
try this:
put battery hot directly to the pump (wires run along driverside floorboard) if it comes on you know its electrical. if it does not, pull the drivers side rear seat bottom (lift up on front of seat and you will see the bolt) and make sure the ground is good. then try to put hot to it again. if it still does not come on you know it's the pump.
more then likley its the pump.
LB985IROC
PostPosted: Sun Feb 26, 2006 3:30 pm    Post subject: Reply with quote
its a 85 iroc-z tpi 305
Retail parts sales
vee-six
LB985IROC
PostPosted: Sun Feb 26, 2006 3:31 pm    Post subject: Reply with quote
oh i also checked voltage at the plug that comes through the floor in fornt of the tank and wiht the car on i get 8 volts
Retail parts sales
vee-six
LB985IROC
PostPosted: Sun Feb 26, 2006 9:51 pm    Post subject: Reply with quote
putting in a new fuel pump.... do i reay have to drop the axle??? oh and my stupid tank has the filer neck as partt of the tank is that stock?
Retail parts sales
vee-six
Sellmanb
PostPosted: Sun Feb 26, 2006 9:56 pm    Post subject: Reply with quote
yep, axle really has to come down, and yep, that's stock. You'll have to manuever around it... dont break it, or it'll cost a LOT to fill up your tank, and the ground, at the gas station.
PostPosted: Sun Feb 26, 2006 10:30 pm    Post subject: Reply with quote
i have done it twice now. it's a two day job. some people claim to be able to do it in a matter of hours, i can't seem to keep it to even one day Confused
Sellmanb
PostPosted: Sun Feb 26, 2006 10:43 pm    Post subject: Reply with quote
a couple hours... with a lift and a nice tranny jack Wink I seen it done in 40 minutes at my work by guys Shocked
LB985IROC
PostPosted: Sun Feb 26, 2006 10:47 pm    Post subject: Reply with quote
lol yea such a gay design wish the could have just put an axcess pane in the trunk area so you could do the whole shizzle from above
Retail parts sales
vee-six
Sellmanb
PostPosted: Sun Feb 26, 2006 10:52 pm    Post subject: Reply with quote
That'd be too easy Wink
Tony and I had his old rear end out in 20 minutes (air tools cut time in half) From there, there should be two gas tank straps that you'll probably need some extensions for. Just make sure you disconnect things from around the fuel tank (this is the hard part cuz half of the things are impossible to see so you have to do it by feel), then drop the tank (use a jack if it's full, if it's empty (gallon or two, no more than) you should be able to bench press it (i'd still use a jack though).
Slowly lower it until it's to the point where you can easily get to the fuel lines connecting to the fuel pump. Take those off, and then grab a hammer and flathead screwdriver, take the collar off around the fuel pump, and voila! Fuel pump out.
Installation is reverse of removal Wink (make sure to put the new base gasket around the new fuel pump too, gas stinks otherwise!)
PostPosted: Mon Feb 27, 2006 1:58 am    Post subject: Reply with quote
i always found the fuel lines easy to remove. the HARD part is getting the tank in and out. trying to do it full would be insanity. bite the bullet and put a syphon hose in it. last time i did not even get any gasoline in my mouth Smile and i got it flowing on the first try Exclamation
even empty the reinstallation of the tank is a two man job. even if the 2nd man is the kid from next door telling you which way the filler neck needs to go. buy him an ice cream.
and one more tip. NO MATTER HOW HARD it is getting the tank in and out, under NO CURCUMSTANCES bend those tank retainer straps. they never bent back to the right shape.
PostPosted: Mon Feb 27, 2006 8:49 am    Post subject: Reply with quote
Don't forget the hack saw to remove the exhaust system.
Sellmanb
PostPosted: Mon Feb 27, 2006 9:29 am    Post subject: Reply with quote
Rodney, thanks! I almost forgot... the exhaust will be in the way. You can take it off the cat and hangers from there - out, or use a sawzall and have a shop weld it back up (I would suggest the first way)
PostPosted: Mon Feb 27, 2006 11:41 am    Post subject: Reply with quote
the second way is more fun, but more expensive Twisted Evil
LB985IROC
PostPosted: Mon Feb 27, 2006 6:58 pm    Post subject: Reply with quote
well i got the whole axle out and the tank exposed in about 2 hours today but about the retainer ring any special way to do it? and it goes right back in reverse???
Retail parts sales
vee-six
Sellmanb
PostPosted: Mon Feb 27, 2006 8:33 pm    Post subject: Reply with quote
you should be able to figure out the way that the fingers hook into the "retainer blocks" (for lack of a better word coming to me ATM), just grab a long fat screwdriver (flathead) and a hammer and tap it away. Putting it back on, you'll probably need another person to push down on the center of the fuel pump (without breaking any plastic lines) so you can get the retaining ring into it's "retaining blocks" and locked into place.
PostPosted: Mon Feb 27, 2006 9:13 pm    Post subject: Reply with quote
the retaining ring comes off by pounding the tabs that stick up in a counterclockwise motion. it is not that hard to get them off by yourself, but help makes it way easy.
also be sure you replace the strainer while you have the pump out.
LB985IROC
PostPosted: Mon Feb 27, 2006 10:55 pm    Post subject: Reply with quote
o0o0o0o
Retail parts sales
vee-six
LB985IROC
PostPosted: Tue Feb 28, 2006 5:12 pm    Post subject: Reply with quote
................replaced the fuel pump didnt do a damn thing
Retail parts sales
vee-six
