breaking in your brake pads
PostPosted: Mon Feb 27, 2006 2:15 am    Post subject: breaking in your brake pads Reply with quote
bobby and i were talking today. my father has always told me to go easy on new break pads for the first hundred miles or so. make long gentle stops, no slamming on the brakes. he says that is how you "glaze the pads" and cause decresed effectivness.
bobby says almost the exact oposite. make many hard stops right off the bat (he had a whole complicated system "go to thirty and slam on the brakes until 5MPh and then slowly stop, and then count backwords from 1,053 and say tje word "blue" and then make a hard stop from 50MPH...." it was complicated and i allready forgot most of it.)
so which is right? a few hard stops or looong gentle slooow stops? any input is appreciated.
PostPosted: Mon Feb 27, 2006 7:00 am    Post subject: Reply with quote
Bobby is right here, you need to bed them, by getting them up to temp.
More info here:
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Do note that with normal street use, you are going to undo the bedding process anyway, since you rarely get them up to proper temp anyway.
PostPosted: Mon Feb 27, 2006 11:39 am    Post subject: Reply with quote
WOW... awsome article. i have been completly in the dark on this Shocked
this bring up another question, where am i agoing to be able to get up to 60MPH and be able to slow down to 10MPH using 90% deceleration of brakes without pissing people off or getting rearended?
PostPosted: Mon Feb 27, 2006 11:46 am    Post subject: Reply with quote
That is the hard part. Also be aware, that the bedding process will wear off, under normal daily driving conditions.
PostPosted: Mon Feb 27, 2006 12:02 pm    Post subject: Reply with quote
so how often should one re-bedin their brakes?
PostPosted: Mon Feb 27, 2006 12:16 pm    Post subject: Reply with quote
Really, bedding them is only going to last a short time. Truth be told, I don't know how long it will last. under stop and go traffic, I have a feeling it is going to wear it out pretty quick.
PostPosted: Mon Feb 27, 2006 12:22 pm    Post subject: Reply with quote
Your process was close except you say the phrase "Red is beautiful"
Very Happy
/end of useful information
