Posted: Mon Feb 20, 2006 11:43 am Post subject: Accessory Compatability. |
Does any one know which accessory's are interchangable, with a pully swap between v-belt cars and serp cars? I know the WP is diffrent, due to the direction it turns. Do you know if the PS pumps are the same, just a diffrent pully? How about the alternator? _________________
Posted: Mon Feb 20, 2006 12:13 pm Post subject: |
Napa Part No.
'87 V Belt
Alt 5 Groove - RAY 2134519D
PS w/ Res - NSP 207831
'90 Serp Setup
Alt - RAY 2134523D
PS w/ Res - NSP 207926
Autozone:
'87 V Belt
Alt -
VALUCRAFT
105 AMP 1341-5-11
GOLD-DURALAST
105 AMP DLG1341-5-11
PS-
CARDONE
WITH RESERVOIR 20-7831
'90 Serp
Alt-
VALUCRAFT
105 AMP 1345-6-11
GOLD-DURALAST
105 AMP DLG1345-6-11
PS-
CARDONE
WITH RESERVOIR 20-7926
I don't think they are interchangable. |
Posted: Mon Feb 20, 2006 4:17 pm Post subject: |
| so you are switching fromthe newer serpentine setup to the older style setup? if not then what is "v-belt"? (i thought v-belt was the 82-86 style) |
Posted: Mon Feb 20, 2006 4:19 pm Post subject: |
yes, switching from the newer style, to the older style. Or at least looking into it.
Shoot. If someone wanted to switch to the new style, I would be willing to trade parts. |
Posted: Mon Feb 20, 2006 4:24 pm Post subject: |
| my GTA has serp, or i would so take you up on that.... |
Sellmanb Member
Posted: Tue Feb 21, 2006 8:34 am Post subject: |
John I dont know if parts from my Camaro would interest you, but I have ALT, WP, PS pumps, and the crank pulley. Brackets are all still attached, with their belts on my Camaro still. The PS belt is new, the one other belt is fine, but it probably wouldnt hurt to have changed.
I RARELY drive the Camaro for obvious reasons, so it would be easy for me to take it all out and give 'em to yah. There's no problems with any of the parts from what I've gathered, I think most that motor's problem is internal.
I could give 'em to yah sometime on your way to work and once you get all your serpentine belt setup off I can meet you on your way to work another day to pick it up (no big hurry) |
Posted: Tue Feb 21, 2006 9:43 am Post subject: |
| Bobby. I'll PM you about this. I'm going to survey the damage tongight. it may be that the bracket is not even usable anymore. I'll have to check. Once I've gotten a good look at the damage, I'll PM you. |
