So, what's wrong with your car?
Goto page Previous  1, 2
84transam383
Banned
PostPosted: Mon Feb 09, 2004 3:23 am    Post subject: Reply with quote
90RSrocks wrote:
Jess wrote:
1 - crappy fitting new nose from GM
2 - E-brake doesn't work
3 - Does the chevy salute
1 - Nose straight from GM and it still doesn't look right? Good grief.
2 - I don't think any 3rd gen e-brakes work that well, do they?
3 - Does the wha???
*shrug* all my ebrakes work great,just need to keep them adjusted properly Laughing
and the good ole chevy salute! that mystical majic puff of blue smoke upon start up!
PostPosted: Mon Feb 09, 2004 4:56 am    Post subject: Reply with quote
Mike, when did all of that go wrong? Shocked Shocked Shocked
Here is my list....
Exterior:
- Nose Wink -- thank you Ford Excursion
Interior:
- Rip on the Drivers Seat
- trim panel above the rear seats is falling off
Engine:
- Very Lean (15.7:1) at WOT
- TPS Values reading wrong
- Vacume leak (still tracking it down, i found a few Doh!
- Evap check valve bad.
- Something i haven't found yet
- Another thing i haven't found yet
- Heck, there is probably still more wrong with it
Suspension:
- I have Stock LCA's still (only stock peice left on the suspension Sad thank you Steve Spohn
Transmision:
- Leaking... haven't found the source yet, but i see what apears to be ATF on th bell housing, and on the garage floor Sad
PostPosted: Mon Feb 09, 2004 8:24 am    Post subject: Reply with quote
Kelly,
Chevy salute = that little puff of blue smoke on start up.
Dewey,
I knew that I couldn't put up with the cat's being broken from a performance and sanity standpoint (marbles in a tin can = sounds terrible). So I went with the cheapest short term solution and decided to gut the cats. Went up to the SSS and B helped me with the exhaust. We didn't even touch then engine. Car had been great on the ride up - even got better mileage after me and Paully did some tuning Thursday night. Anyway, started the car up and it started backfiring and stuttering. Took valve cover off and the rocker for #1 E was sitting there. Poly lock still had the rest of the stud in it - just snapped right off. So I don't know if it had been getting loose or if it just went. I am impressed with AFR's flow numbers but that is about it. Brandon found several threads where people talk about the same thing happening. Looks like AFR uses way cheap studs on their way expensive heads Rolling Eyes . I am going to buy some ARP studs and get it going again - maybe this week.
PostPosted: Mon Feb 09, 2004 8:40 am    Post subject: Reply with quote
i have a full set of ARP studs in the 'Warehouse' if you need something, i know money is tight for you right now, and i won't be using them for a couple more months, so you are welcome to them, so long as you buy me a set eventualy.
PostPosted: Mon Feb 09, 2004 8:42 am    Post subject: Reply with quote
You rock!
PostPosted: Mon Feb 09, 2004 6:08 pm    Post subject: Reply with quote
I don't even want to type that much, so I'll just list what is good about the car right now.
-radiator cap is in good shape.
-steering wheel is still attached
-u joints are in fine shape
-2 tires have fair tread left on them
-dome light works
That pretty much sums up my ride. Embarassed
Got to get this beotch ready for the cows gathering. Cool
z28redline
PostPosted: Mon Feb 09, 2004 7:12 pm    Post subject: Reply with quote
Haven't driven the Z for what seems like forever so I've forgotten about all of those minor problems. It's currently stripped down awaiting body work and paint.
Schultzy, sucks about the stud but really it could have been worse like the head of a valve or something.
z28redline
View user's profile Send private message Visit poster's website MSN Messenger
kidcamaro
PostPosted: Mon Feb 09, 2004 7:22 pm    Post subject: Reply with quote
mine needs a bit of touch up paint.
interior needs a bit of work.
need to change the egr valve.
need a new muffler soon. Sad
TecherB
Princess B
PostPosted: Mon Feb 09, 2004 9:26 pm    Post subject: Reply with quote
-dome light works
LMAO
tough lick mike maby you can get it running better by the end of the month
PostPosted: Mon Feb 09, 2004 10:09 pm    Post subject: Reply with quote
Yeah it could have been a lot worse. The rev kit holds the lifters in real nice and the valve covers aren't dented (a little scratched on the inside Wink). John is going to give me a ride up Thursday after work. I will just replace the one stud and get her home then do the others and the intake gasket. I am glad that the miniram is easier to work on but last may i didn't think i would be doing it this often - lol.
My list is much longer but it's depressing to see.
Page 2 of 2
