Power Seat track.
Z28Chick
New Member
PostPosted: Sat Jan 31, 2004 1:57 pm    Post subject: Power Seat track. Reply with quote
Well, I recently replaced my drivers seat with a red/black APC seat and as my brother was putting it in he realized that it was too tall with the power seat track so now I have no use for it.
It works great, all the adjustments work, and it will come with the power seat switch adjuster and everything you need just in case your car wasn't a power seat car.
I'd like to get $50 for it. Smile
Yes, I am a girl. Very Happy
kidcamaro
PostPosted: Sat Jan 31, 2004 3:18 pm    Post subject: Reply with quote
i got a question. will it work for the passenger side?
Roshambo
PostPosted: Sat Jan 31, 2004 10:24 pm    Post subject: Reply with quote
Hey Corey.. since my sister isnt here I guess I can answer that. We used a manual passenger side track on her drivers side, and the front studs line up perfectly in the front.. on the back I had to use an adapter, but it's really simple to fab up. If you wanted it I could cut out the adapters and I'll just toss em in with the track.
Hope that helps! Smile
-Joe
PostPosted: Sat Jan 31, 2004 10:26 pm    Post subject: Reply with quote
The problem is, the controls will be on the left side of the seat, against the console.
If you turn the track around, the controls will be on the right, however, the seat will be positions too far forward or too far reversed because of the offset of the track.
kidcamaro
PostPosted: Sun Feb 01, 2004 9:50 am    Post subject: Reply with quote
if i can afford to get it this next check i will. i will use it for my seat cuz my front corner is busted. if ya could send the adapters too that would be cool. that way i can try to make it work for the passendger side. maybe i can find a way to mount the controls on the other side or something.
Demon
PostPosted: Sun Feb 01, 2004 4:57 pm    Post subject: Reply with quote
off topic...
pics of the new seat installed?
Roshambo
PostPosted: Sun Feb 01, 2004 8:58 pm    Post subject: Reply with quote
Well.. there is enough length on the harness for it to be mounted either in front of the seat or on the side (near the door)... I'll measure and cut the adapters and include those also.
The controls would only be on the left side if you use the stock pastics.. Smile
I dunno how much shipping would be.. probably about the same for the gas money. Doh!
-Joe
kidcamaro
PostPosted: Sun Feb 01, 2004 10:17 pm    Post subject: Reply with quote
ill check on shippin too this week. then ill know by friday. maybe if i have enough extra money me and the wife can make a trip down or something.
