doc76239 Member
Joined: 16 Dec 2004 Posts: 70 Location: Marysville,WA
Posted: Mon May 16, 2005 6:27 am Post subject: 88, 10bolt posi rearend |
i'm selling my 88, 10 bolt posi rearend. disc brakes, sway bar, parking cables. all for $350 O.B.O. or full/partall trade for following items. 89 ish formula passenger side fender, both doors, prefer power, wrap around spoiler, 16X8 rear formula rims. I have an 89 firebird formula i'm trying to fix up. e-mail me at doc762399@aol.com _________________ My bird eats ponies |
Sellmanb Member
Posted: Mon May 16, 2005 4:30 pm Post subject: |
just to help you get this one rolling... what gears are in it  |
doc76239 Member
Posted: Tue May 17, 2005 2:45 am Post subject: ? |
I'm not sure what gears are in it. I will be taking the cover off of it today, then I will post them. I forgot to write the gear ratio down when I changed the gear oil about 4 months ago. _________________ My bird eats ponies |
84transam383 Banned
Posted: Tue May 17, 2005 6:11 pm Post subject: |
| fyi just to help your sale.... i doubt youll get 350 out of that rearend...thats certainly on the high side for a used posi rear. might want to consider going a tad lower |
kurfbird Member
Posted: Wed May 18, 2005 9:42 am Post subject: 84transam383 |
Sorry to hijack your post. 84transam383 Have Pm you engine and rims _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
doc76239 Member
Posted: Wed May 18, 2005 12:25 pm Post subject: ??????????????? |
That's why it says 350 O.B.O, i'm intrested in all resonable offers. I used it for a replacement rearend in my 89 friebird formula why I aquired the parts to rebuild my 9 bolt. my 9 bolt is back under my cars and this one is extral. i'm seeing open disc braked 10 bolts, no brakes, no sway bar, go for 100. this is a full rearend for someone doing a drum to disc conversion. _________________ My bird eats ponies |
doc76239 Member
Posted: Sun May 22, 2005 7:08 am Post subject: Hmmmmmmmmm |
I pulled the cover. only numbers I found were 11:41. so that is 11 pinion gear teeth, 41 ring gear teeth. 41 divided by 11 = 3.72 gear ratio. does that sound right? I have some pics. let me know. _________________ My bird eats ponies |
ET phone hoME Member
Posted: Sun May 22, 2005 5:00 pm Post subject: |
i have 3.73 ratio in my v6 if you wanted to know _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
doc76239 Member
Posted: Sun May 29, 2005 11:19 pm Post subject: 250.00 |
now for sale at 250.00, any takers? _________________ My bird eats ponies |
