Cascade Crew Message Forums
84transam383 Banned
Posted: Wed Jan 28, 2004 10:24 pm Post subject: Some misc Stuff i have no use for... |
SBC 400 ,std bore,i bought it from the machine shop awhile back,its been tanked and cleaned,its a 73 block with 2 bolt mains,caps and bolts are there,has no freeze plugs or bearings,it would need to be punched 30 over{although it will clean up fine with a .020 overbore},i bought this to make either a 406,or 377 for my 86t/a thats going to be the "race car" but im going to big block it instead after some thought.
asking 175 obo for it. id hang on to it,but i could use some extra $$ for my 383 buildup
also have complete 84 T/A interior,dash,seats,console,everythings in mint condtion{came out of my 84 t/a with 74k original miles on it}
seats are dark grey highback buckets,cloth centers with leather/vinyl sides
dash is 100% complete with TRANSAM leather map pocket,also have gauge cluster,stock hvac controls,and the console with all the trim,nothing is cracked or broken,console is setup for pwr windows and a 5spd.
make offer on all that stuff,or whatever yua need.
rear hatch with "flat" style firebird spoiler,its red,complete hatch with perfect glass,no rear defrost
make an offer..
v6 t5 with bellhousing,it was in a customers car,i replaced the clutch and trans in the car...i never got the chance t oactually drive it with this transmission,but i went through the gears on the lift with the motor running,didnt make any noises,but didnt engage the gears all that well{the clutch was foobarred too,inertia springs were missing from the clutch disc}
come pick it up and its yours. btw,also has the shifter.
also,i just purchased a 84 L69 automatic T/A black and gold hardtop,its 100% complete and in decent shape,ill be parting it out here sometime soon,its got 3.73 posi disc rearend,700r4,the 9.5 to 1 305 HO which runs good,the car will be at my shop in albany hopefully by friday or saturday,anyone needing parts,or wanting the whole car,feel free to come down and drive it or check it out if yua want.
otherwise,make inquiries on anything you'd like/need/want and ill get some pics ASAP when the cars in my possesion{hopefully by the weekend} |
Roshambo Member
Joined: 08 Jan 2004 Posts: 280 Location: Sacramento, CA
Posted: Wed Jan 28, 2004 11:30 pm Post subject: |
Damn you Mark.
-Joe _________________ 1970 Cadillac Sedan DeVille Hardtop - 472/TH400, Air Bags with 10 switches, Memphis Audio.
84transam383 Banned
Posted: Wed Jan 28, 2004 11:37 pm Post subject: |
this gonna be cash,charge or Mr barnes Financing? |
Posted: Thu Jan 29, 2004 5:05 pm Post subject: |
| How, much for the 3.73 rear end? |
miamivice Member
1982 Pontiac Trans Am
Posted: Thu Jan 29, 2004 6:53 pm Post subject: |
where exactly are you located? _________________
Roshambo Member
Posted: Thu Jan 29, 2004 10:30 pm Post subject: |
| rjmcgee wrote: | | How, much for the 3.73 rear end? |
Sorry RamRod, I beat you to it dude.
-Joe |
84transam383 Banned
Posted: Fri Jan 30, 2004 12:10 am Post subject: |
| miamivice wrote: | | where exactly are you located? | Scio oregon,the parts are located at my shop in Albany oregon,about an hour south of portland,or an hour north of eugene,15 minutes from salem  |
84transam383 Banned
Posted: Sun Feb 08, 2004 1:46 am Post subject: |
| Roshambo wrote: | | rjmcgee wrote: | | How, much for the 3.73 rear end? |
-Joe | actually rodney,its back up for sale,anything off the car... heres the RPO LIST...
AAA : 4-WAY MANUAL SEAT ADJUSTER
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AM9 : SEAT, RR, SPLIT, BACK, FLDG
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
BV8 : ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
B20 : ORNAMENTATION, INTR, LUXURY
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DX1 : STRIPE, FRT END, HWD
D03 : PAINT, PROCESS, WATER BASE
D1T : GEAR, SPEEDO DRIVEN
D35 : MIRROR, OUTSIDE REAR VIEW
D80 : SPOILER, RR END PNL
D85 : STRIPE, B0DY SIDE LOWER ACCENT
E5Z : SPEEDOMETER ADAPTER (DELETE)
Unable to locate code E6N in our database!
GT4 : AXLE REAR, 3.73 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K19 : REACTOR SYSTEM, AIR INJECTION
K22 : GENERATOR, 94 AMP
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
L69 : ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NB1 : EMISSION SYSTEM, CLOSED LOOP
N33 : STEERING COLUMN, TILT TYPE
N78 : WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
TR9 : LAMP, GROUP
T93 : LAMP, TAIL & STOP, SPECIAL
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UQ7 : SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER
Unable to locate code TU1 in our database!
UU7 : RADIO, AM/FM STEREO, CASS, CLOCK ETR
UT1 : TONE GENERATOR, WARNING
U23 : CLUSTER, INST, TRIM ODOM
U25 : LAMP, INTR, RR COMPT, COURTESY
U27 : LAMP, INTR, I/P COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U73 : ANTENNA, FIXED, RADIO
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WS4 : MODEL CONVERSION, TRANS AM
Unable to locate code WS5 in our database!
WS6 : PERFORMANCE PACKAGE, SPECIAL
Unable to locate code WY6 in our database!
W62 : ORNAMENTATION, AERO PACKAGE
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Y06 : RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
19U : PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
55A : STRIPE COLOR, ACCENT, GOLD (91)
Unable to locate code 55P in our database!
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
64C : TRIM COMBINATION, CLOTH, LT BEIGE (C) (92)
Unable to locate code 641 in our database!
649 : SEAT BELT COLOR, LIGHT BEIGE (9) (92)
7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
9NM : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
http://community.webshots.com/album/115472389UvHSRt
http://community.webshots.com/album/116841571DmFgDr
heres a bunch of pics of the two cars ive recently purchased,the white ones spoken for already *squint@ joe dirt*
black ones gonna be a parts car unless someone wants it complete,ill give it till friday before i part it out,800 buys the whole thing,this runs and drives GOOD i might add,will need a tuneup though. |
Posted: Sun Feb 08, 2004 8:00 am Post subject: |
| So how much for the rear end? Pm me or something. |
84transam383 Banned
Posted: Sun Feb 08, 2004 1:44 pm Post subject: |
forgot,i also have a 3 inch catback off a late 90s z28 i parted out 97 i beleive,has the 3 inch mandrel bent pipe leading to the stock 2.5 outlet muffler with Z28 flat tips{i was gonna use it,but bought a hooker instead } |
Reapist New Member
Posted: Mon Feb 09, 2004 6:33 am Post subject: |
| Do you still have the 400 small block? Do the heads and crank go with it? Thanks. If yes to all of the above I'll probably buy it. |
84transam383 Banned
Posted: Mon Feb 09, 2004 7:41 pm Post subject: |
| Reapist wrote: | | Do you still have the 400 small block? Do the heads and crank go with it? Thanks. If yes to all of the above I'll probably buy it. | yeah i still have the 400sbc,its just a bareblock,although i could give you the 1.94 1.50 heads and a perfect standard 350 crank for it { if you wanted a 377},i dont have any of the actual 400 internals,i bought the block bare. but ill throw the heads and the 350 crank in if youd like. |
Reapist New Member
Posted: Sun Feb 15, 2004 4:37 pm Post subject: |
| I have to see how this new vortec engine pans out I was offered. |
84transam383 Banned
Posted: Sun Feb 15, 2004 5:01 pm Post subject: |
| Reapist wrote: | | I have to see how this new vortec engine pans out I was offered. | the 400 is gone anyways,sold it saturday |
miamivice Member
Posted: Mon Feb 16, 2004 10:01 pm Post subject: Re: Some misc Stuff i have no use for... |
| 84transam383 wrote: |
if actualy decide to part it out, i might be interested in the interior plastics, fenders, and tail lights. ill IM in a bit. hell, im tempted to buy the whole thing off you and cut the roof off to make myself a convertible KITT
later pal! _________________
84transam383 Banned
Posted: Tue Feb 17, 2004 12:37 am Post subject: Re: Some misc Stuff i have no use for... |
| miamivice wrote: | | 84transam383 wrote: |
later pal! | if your gonna purchase yua better do it quick i started parting it out this evening,i took the bumpers,gfx,and headlights out,as wel las the tail lights,started pulling the rearend as well,but its still i nthe car. anyways,if your really interested let me know ASAP because i want this thing gone {which is why i decided to part it out}
still runs and drives btw. |
miamivice Member
Posted: Tue Feb 17, 2004 11:05 am Post subject: |
| just PMed ya about it |
Midnight Sun Member
Posted: Wed Feb 18, 2004 1:12 pm Post subject: |
I think I PM'd ya, cant remember.
Whatis the condition of the weatherstripping on the doors? And that little felt piece of weather stripping that runs along the windows. As well as that triangular filler piece?
And the front blinkers next to the headlights? _________________
84transam383 Banned
Posted: Wed Feb 18, 2004 1:40 pm Post subject: |
| Midnight Sun wrote: | I think I PM'd ya, cant remember.
And the front blinkers next to the headlights? | doors have been sold { i think}
the turnsignals up front are in perfect shape. |
miamivice Member
Posted: Fri Feb 20, 2004 2:37 pm Post subject: |
anyone up north need anything (midnight sun??), im making a run down to albany tomorrow....
drop me a line --> 206-941-1429
~Farshin _________________
