kurfbird Member
Posted: Fri Apr 01, 2005 10:16 am Post subject: Brake system |
Iam selling a complete brake system form my 87 Trans Am. including calipers, lines, rotors (that need turned) and can be, also with bearings.
I also have the rear system with wheel cyl rear drums I will checked for turnability. and springs etc. Pads are worn.
ALso have Lines master cyl and brake booster
WIll sell seperate
100.00 OBO.
kurfbird _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
Wolffy Member
Posted: Fri Apr 01, 2005 12:12 pm Post subject: |
is one of these from a disc rear end ? what year ?
how much for the prop valve ? |
Midnight Sun Member
Posted: Fri Apr 01, 2005 12:18 pm Post subject: |
What is the gearing on your rear end, and does it have disc? _________________
Wolffy Member
Posted: Fri Apr 01, 2005 12:22 pm Post subject: |
| gear ratio is 3:73 and yes im converting to 4 wheel disc |
kurfbird Member
Posted: Fri Apr 01, 2005 1:00 pm Post subject: Brake system |
The front is disc
The rear is drum
Iam unsure of the gear ration becuse no RPO decorder.
If your interested in the rear with drums let me know. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
brucesthirdgenparts.com |
