		| Author | Message |
		| 90RSrocks Member
				|  Posted: Thu Mar 17, 2005 7:13 pm    Post subject: Car is running rough |   |
				| Today I fired up the Maro for the first time in months. Good news; it started easy and runs fine at idle. Bad news; when it gets into mid-range RPMs it stumbles and runs very rough. I've looked/listened for vacuum leaks but I don't think that would be it since I replaced all the vacuum lines last summer. Any thoughts on what else I should check?
 One thing I want to check is the timing but I don't have a timing light. Any chance I can borrow one from a fellow crewbie for long enough to check it out?
		| Back to top |  |
				|  Posted: Thu Mar 17, 2005 7:31 pm    Post subject: |   |
				| Crappy gas? Water in the gas? |  |
		| Back to top |  |
		| CheezX Member
				|  Posted: Thu Mar 17, 2005 7:38 pm    Post subject: |   |
				| It does sound ignition related, but I don't think the timing would be off from letting it sit. I'd look at the cap and rotor to see if they corroded, also check other usual stuff like plugs and wires. |  |
		| Back to top |  |
		| 90RSrocks Member
				|  Posted: Thu Mar 17, 2005 8:20 pm    Post subject: |   |
				| Yeah I thought about crap in the gas too, I think tomorrow I'll put something in to dry it in case there's water in there.
 It's more than just sitting over the winter since I checked timing, I haven't checked timing on this car ever.
  That's why I'd really like to make sure that's good before I do much other stuff.
 I had to replace the cap/rotor about a year ago, I'll check them but I suspect they are fine since they are pretty new. Wires are on snug, they look fine. They are pretty new. Didn't check plugs yet, I'll do it tomorrow.
		| Back to top |  |
				|  Posted: Thu Mar 17, 2005 8:33 pm    Post subject: |   |
				| cheesy might be right, might have collected some moisture in the cap. |  |
		| Back to top |  |
		| Schultzy89GTA M.R.A. (11sec Club)
 1989  Pontiac  GTA
				|  Posted: Thu Mar 17, 2005 9:03 pm    Post subject: |   |
				| You can borrow my light Kelly. Did you change stores or are you still at Lloyd? I could bring it to work tomorrow if you were going to be at Lloyd during the day. Otherwise just PM me and we can figure it all out.
		| Back to top |  |
		| rjmcgee The Hammer
				|  Posted: Thu Mar 17, 2005 10:06 pm    Post subject: |   |
				| Make sure both spark plug wires are hooked up.  |  |
		| Back to top |  |
				|  Posted: Thu Mar 17, 2005 10:42 pm    Post subject: |   |
				|  	  | rjmcgee wrote: |  	  | Make sure both spark plug wires are hooked up.  |
		| Back to top |  |
		| 90RSrocks Member
				|  Posted: Thu Mar 17, 2005 11:52 pm    Post subject: |   |
				| Alrighty then, guess I might as well fly this flag myself...
		| Back to top |  |
		| 90RSrocks Member
				|  Posted: Thu Mar 17, 2005 11:54 pm    Post subject: |   |
				|  	  | Schultzy89GTA wrote: |  	  | You can borrow my light Kelly. Did you change stores or are you still at Lloyd? I could bring it to work tomorrow if you were going to be at Lloyd during the day. Otherwise just PM me and we can figure it all out.
 Thanks for the help Schultzy! I am up the street at the NE MLK blvd & Ainsworth store now. PM on the way!
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Fri Mar 18, 2005 6:07 pm    Post subject: |   |
				| When I had the stock small cap HEI my car would go through a cap a year. Some reason those collect moisture and corrode more then any other. And you dont have to drive it to have it happen. Definately take a look at your cap. And add some heet, and maybe some injector cleaner to the gas if its been sitting awhile. |  |
		| Back to top |  |
		| 90RSrocks Member
				|  Posted: Sat Mar 19, 2005 3:19 am    Post subject: |   |
				| I'll be darned, I never thought it would go that fast! I'll put it on the list of things to check tomorrow. I want to narrow down the list of possible culprits as quick as possible. I can't handle not driving it for much longer. I'm like a junkie past due for his fix, man! I gotta have some Maro!  |  |
		| Back to top |  |
		| chevymad Master B
				|  Posted: Sat Mar 19, 2005 9:56 am    Post subject: |   |
				| Ya.. its pretty strange with the small caps. I still get 70s vehicles in the shop that have the large cap hei, and the original cap, still in good shape. Yet I couldnt keep a good brass terminal cap on the formula for more then a year.
 Also weird is that the accell distributor i'm using now has a small mopar type cap. And it has no problems at all. In fact its probably 5 or 6 years old. And been on this car 3 years.
		| Back to top |  |
		| 90RSrocks Member
				|  Posted: Sat Mar 19, 2005 1:57 pm    Post subject: |   |
				| Probably has to do with how well the unit seals up to keep moisture out. Just a guess using my mad logic skillz.  |  |
		| Back to top |  |
