Defrost switch
kurfbird
PostPosted: Fri Mar 11, 2005 2:00 pm    Post subject: Defrost switch Reply with quote
I have a firebird 1989 2.6 700 R4 that did not come with a rear defroster. I got a switch and wiring but when I hooked up the switch there is no voltage coming out of the connector. ALso when I push the switch It does not lock into position. and the light does not come on.
Can some on help me out and let me know how there works on there Firebird.
If you have a spare working switch let me know. Maybe we can work something out.
Thanks
Kurbird
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PonchoTA
PostPosted: Fri Mar 11, 2005 3:24 pm    Post subject: Reply with quote
Make sure power is getting to the connector. Usually if an option is not installed, the FUSE is not installed, but all the wiring may be there.
I'd check there first before giving up on the switch.
hth
Paully
kurfbird
PostPosted: Fri Mar 11, 2005 8:29 pm    Post subject: defrost switch wiring Reply with quote
I ve tried to trouble shooting the defrost switch but when I push the button the switch does not lock.
Does any of your switch lock even when there is no power.
I have even try to bench test the switch to the battery. Still no voltage going to the defroster.
If I take the power wire and jump it to the defrost wire I get power.
Hook up power to the switch many different ways to the batteery but still no power will come out of the switch.
Give me some help here.
Kurfbird
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
JohnnyIROC-Z
1995 Pontiac Formula
PostPosted: Sat Mar 12, 2005 8:26 pm    Post subject: Reply with quote
The switch doesn't lock, when you push it down the little amber light should come on.
kurfbird
PostPosted: Sat Mar 12, 2005 8:30 pm    Post subject: Reply with quote
It doesn't
Tried to direct wire to the battery and it still would not work. I need a new switch. It might be that the switch that I got from J/Y was from a 86
kurfbird
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
JohnnyIROC-Z
PostPosted: Sat Mar 12, 2005 9:42 pm    Post subject: Reply with quote
naw that wouldn't make a difference, but it's possible you have a bad switch ?
kurfbird
PostPosted: Sat Mar 12, 2005 11:08 pm    Post subject: defroster Reply with quote
Yea the switch is bad now. I also found a conector on passinger side that comes from the switch. Will go to the J/Y monday and get the relay and switch.
I hope that this does it.
Kurfbird
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
JohnnyIROC-Z
PostPosted: Sun Mar 13, 2005 9:44 am    Post subject: Reply with quote
Good luck man, If you run into trouble finding one or something let me know and I'll go and hunt one at the yards. shouldn't be THAT hard.
kidcamaro
PostPosted: Sun Mar 13, 2005 10:58 am    Post subject: Reply with quote
you might be able to use a momentary toogle switch instead. i had to use one before. it didnt light up but it worked.
kurfbird
PostPosted: Wed Mar 16, 2005 1:11 pm    Post subject: Defrost switch Reply with quote
Finally got it working. Replaced switch. Then it staarted to work.
Now I need a Rear Hatch with defrost that will fit a 1989.
Thanks for all the help.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
