Posted: Sun Dec 11, 2016 10:56 pm Post subject: Help me choose color of my gauges (before sale ends Friday!) |
Get your artistic groove on. I need help choosing color of some Speedhut gauges.
A lot of people do white. I can't see why, that looks horrible. And the Speedhuts in particular look like a baseball.
These blood red gauges look really cool by themselves. Not sure they look good in my car though.
Black always works but doesn't give a custom look. Also doesn't screw up the look either!
Posted: Mon Dec 12, 2016 7:10 am Post subject: |
I'm thinking about buying a set of Speedhuts too since my AutoMeters are flaky, inaccurate junk. Personally, I like an understated look so I will be going with black face, white letters and green illumination to match the Delco stereo. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Dec 12, 2016 7:45 am Post subject: |
| Go black, the other pictures you showed looked pretty bad with that dash and layout. |
Posted: Mon Dec 12, 2016 8:32 am Post subject: |
| Dewey316 wrote: | | Go black, the other pictures you showed looked pretty bad with that dash and layout. |
This.
Normally I much prefer a white face, but SpeedHut's white gauges do look goofy as your photoshop illustrates. |
Posted: Mon Dec 12, 2016 6:25 pm Post subject: |
| Out of those choices, definitely the black. |
Posted: Mon Dec 12, 2016 7:09 pm Post subject: |
| Seems unanimous. I'll probably do that black. |
Posted: Tue Dec 13, 2016 4:44 pm Post subject: |
Frankly, I don't even want new gauges but my tach doesn't keep up at higher rpm's and I never know where is redline and when to shift. Doesn't bother me on the street because I drive by sound at those speeds, but it became a real hassle at the drag strip with the engine bouncing off the rev limiter every gear.
The tach is very accurate at lower speeds. I think the problem at high rpm has something to do with the RC constant of the circuits but I don't know how to fix that. Would love to keep using the stock tach if it would work better between 6000 - 7000 rpm. |
Posted: Tue Dec 13, 2016 5:57 pm Post subject: |
| Why not just install a subtle shift light? |
Posted: Tue Dec 13, 2016 7:11 pm Post subject: |
| QwkTrip wrote: | | The tach is very accurate at lower speeds. I think the problem at high rpm has something to do with the RC constant of the circuits but I don't know how to fix that. Would love to keep using the stock tach if it would work better between 6000 - 7000 rpm. |
I would guess they work similar to the camaro gauges. If so , I have a write up somewhere in the archives of this forum, with what pins to test and what resistance you want, and how I fixed mine. |
izcain 9sec Club
Posted: Tue Dec 13, 2016 7:18 pm Post subject: |
The black looks good. _________________
9.17 @ 148 |
Posted: Tue Dec 13, 2016 9:13 pm Post subject: |
| aaron_sK wrote: | | Why not just install a subtle shift light? |
I still want the tach to read right. The Speedhut tach has a built in stack of programmable shift lights..... lured in by that feature. |
Posted: Thu Dec 15, 2016 7:39 pm Post subject: |
Something is on order.  |
Posted: Thu Dec 15, 2016 7:40 pm Post subject: |
| QwkTrip wrote: | Something is on order.  |
You mean red? lol |
Posted: Thu Dec 15, 2016 7:46 pm Post subject: |
PINK!!!  |
Posted: Thu Dec 15, 2016 8:47 pm Post subject: |
For that JDM style I know Jon is after.  |
Posted: Thu Dec 15, 2016 10:34 pm Post subject: |
| We can borrow from the food industry and call it Asian Fusion. Make it so popular that it gets it own forum at thirdgen.org. |
izcain 9sec Club
Posted: Thu Dec 22, 2016 8:35 am Post subject: |
| QwkTrip wrote: | Frankly, I don't even want new gauges but my tach doesn't keep up at higher rpm's and I never know where is redline and when to shift. Doesn't bother me on the street because I drive by sound at those speeds, but it became a real hassle at the drag strip with the engine bouncing off the rev limiter every gear.
I just mounted a big ol autometer and took care of that j/k I kept the stock tach though because I like glancing and seeing it wrapped lol
So you settle on black then? _________________
9.17 @ 148 |
Posted: Thu Dec 22, 2016 11:02 am Post subject: |
| I am letting the suspense hang in the air until I can take pictures. It will be a month before the gauges even show up on my door step. |
