GM Pig Tails
PostPosted: Wed Jan 20, 2016 6:02 pm    Post subject: GM Pig Tails Reply with quote
Need me a pair of 4th gen V8 Electric fan pigtails/connectors. Anyone got a left over harness laying around or a direction to find them short of junk yarding?
PostPosted: Wed Jan 20, 2016 6:26 pm    Post subject: Reply with quote
LT1 era should be Dorman 85101, not sure if LS era stuff is the same or not.
Is this for your Dad's second gen?
PostPosted: Wed Jan 20, 2016 6:49 pm    Post subject: Reply with quote
Yep for the 2nd gen. It's a LS1 era fan not sure if that's the same. I'll check out your part number.
PostPosted: Wed Jan 20, 2016 6:50 pm    Post subject: Reply with quote
Looks like it could work. The connector in the picture has a step on the sides, the fan does not, it's just open. Likely will work!
$16 though. Hmm. And I need two. Pick N Pull doesn't list any 4th gen
http://www.ebay.com/itm/Fan-Connector-Pigtail-Wiring-Harness-Corvette-Camaro-TPI-LT1-LS1-LS6-Cooling-/151562248314?hash=item2349d0607a:g:tLwAAOSw0e9UwR3i&vxp=mtr
This guy claims it does and looks just like the dorman one.
Saw some guys on forums use spades (barf)
PostPosted: Wed Jan 20, 2016 7:37 pm    Post subject: Reply with quote
Recently used Repairconnector.com for a connector on my jeep locker sensor. Not the cheapest but they have alot of stuff.
