Fuel pump whine
PostPosted: Tue May 12, 2015 10:08 am    Post subject: Fuel pump whine Reply with quote
After shutting my car off, fuel pump seems to keep running for quite a while, especially if the engine isnt completely warm when I turn off the key.
If I remember correctly, isnt this a dead give away for a bad oil PSI sender?
'88 FORMULA
PostPosted: Tue May 12, 2015 5:28 pm    Post subject: Reply with quote
May not be bad. If the oil is cold and thick it will hold oil pressure for a little bit. As long as the oil pressure is higher then the minimum the switch is set for the pump will continue to run.
PostPosted: Tue May 12, 2015 10:16 pm    Post subject: Reply with quote
So its somewhat normal for the pump to run 5ish seconds after I turn off the key?
PostPosted: Wed May 13, 2015 6:20 am    Post subject: Reply with quote
Yes. See it many times. It's just the oil pressure bleeding off.
PostPosted: Wed May 13, 2015 8:10 am    Post subject: Reply with quote
I have noticed it more since the new engine.
PostPosted: Wed May 13, 2015 4:21 pm    Post subject: Reply with quote
Clearances are probably tighter so the pressure bleeds off slower.
PostPosted: Wed May 13, 2015 6:47 pm    Post subject: Reply with quote
That's what I was thinking. The factory oil pressure gauge pegs out when the engine is still warming up and 2k rpm. Comes down to around 25-30 warm idle.
