02 sensors
90droptoproc
PostPosted: Sat Feb 26, 2005 1:21 am    Post subject: 02 sensors Reply with quote
would the 02 sensor from a 2.8 or 3.1 mpfi motor be the same as the one for my 91Z 350TPI?
thanks in advance
Rich
PostPosted: Sat Feb 26, 2005 8:03 am    Post subject: Reply with quote
Not sure, but get a Delco. I lost 2mpg when I took out an old ACdelco in my 4.3L Jimmy, and put in a new Bosch.
laegion
PostPosted: Sat Feb 26, 2005 8:46 am    Post subject: Reply with quote
yes they are the same
95 vw jetta gl
currently looking for a cheap ninja 250 or 500 or comperable 2cyl sportbike.
CheezX
PostPosted: Sat Feb 26, 2005 9:08 am    Post subject: Reply with quote
Yeah, the Bosch ones are crappy, go Delco or NGK.
90droptoproc
PostPosted: Mon Feb 28, 2005 11:23 pm    Post subject: Reply with quote
so I should be ok useing the one from a 2.8 corsica?
thanks for all the replies guys
CheezX
PostPosted: Tue Mar 01, 2005 12:34 am    Post subject: Reply with quote
lol, I didn't figure out it was you rich, until I saw your post on the other thread. 2.8 sensor should work, if you need I have a whole bunch of heated O2s with the heater burnt out. They would work just fine for you since you still have stock manifolds.
90droptoproc
PostPosted: Tue Mar 01, 2005 8:42 am    Post subject: Reply with quote
thanks cheez!
